cab divider chrome
anyone have any good oics of cab devider chrome on back of cab
common sense isn't so common anymore |
Re: cab devider chrome
Are you looking for a set of the trim,i have a few sets here and can get pics?
yea i will need some trim but what i'm looking for right now is a pic of the back of a cab showing the exact location in respect to the body line. the back of my cab was dented pretty bad and want to see where chrome sits if it will hide the line on the ridge or how much more sculpting i need to do
i can help ya out, hmm well after going through 300 67-72 pics, i couldn't find a good one, but the trim goes from the bottom of the driprail, to the other side. so where the driprail ends is where the trim goes.
Re: cab divider chrome
Here is a couple pic's, they are not very clear but the chrome is right were the bronze meet the white.
Mats.. ---------------------------------------------------- 1971 Cheyenne Super Custom Camper 475CBB/TH400/AC 1992 Silverado Sport Truck 1988 Silverado 2500 Ext Longbed 4x4 2001 GMC Sierra SLT 4x4 1990 Chevrolet K3500 1965 Pontiac Grand Prix 1980 Z 28 350/4-speed/AC/T-top 1980 Camaro Coupe V6/3-speed 1979 Buick Century Wagon |
thanks for the pics, thats where i thought it would go
Keep in mind you need special rivits that are set into the body for that trim to work. If your cab was not set up originaly you may have a hard time getting them installed.
Kevin |
Yes as Rokcrln said there are rivits in the body to attach the trim.
I took off the trim on mine awhile back and here are some pics of the rivits and the clips holding the trim to the body.
Clips
i wasn't aware of the pins required to hold the clips is it possable to pop rivet the clips on. anyone ever do this with success? how about aftermarket clips?thanks for the heads up and photos guys
Some body shops have the tooling to weld them on. I have it if you want to swing by
![]() Kevin |
a buddy of mine has a stud welding gun i'll check it out and see if it will take the adaoter or if he has it. thanks again
#13 |
TOTY 2006
![]() Join Date: Dec 1999
I used stainless steel screws (don't remember size, 6, 8, or 10) but the head of the screw is about the same size of original stud heads. Email GMCPaul as he has the measurements of each stud and should be able to give that to youl.
Once each hole is drilled, put the plastic clip in place and tighten the screw. I used a sealer on the threads to seal up the hole, prevent rust, hopefully act as a threadlocker. Last edited by John Fabris; 03-07-2006 at 01:47 PM. |
