Old 03-05-2006, 05:55 AM   #1
willow72
willow72's Avatar
electric choke & gas gauge?
does anybody know how hard it is to convert a eletric choke to manual choke is there a kit? have not had very good luck with my eletric choke on my demon any help in the right direction would be great thanks a bunch in advance. also i did a blazer tank install on my truck a while back and i drove around for about a month without putting any gas in the tank [was still running off tank in cab untill i ran new fuel line] is it possible that my float on my sending unit got stuck in the empty position with all the bouncing around with no gas in it because the gauge is stuck on 1/8 of a tank and im pretty sure the gauge is working because when i disconnect the wire the gauge moves help im tired of keeping track of milage to know how much gas i have thanks again for any help john
willow72 is offline   Reply With Quote
Old 03-07-2006, 06:31 PM   #2
willow72
willow72's Avatar
Re: electric choke & gas gauge?
ttt
Old 03-07-2006, 09:20 PM   #3
HotRod71
Short, Fleet, Slammed, V8 Club
There is something to do with ohms and your sending unit matching your gauge and everything. Hope I didn't confuse you more. I know someone else on here can tell more about it.
71 Chevy SWB Fleetside (WIP)
www.4x4grace.com
HotRod71 is offline   Reply With Quote
Old 03-08-2006, 07:24 AM   #4
Bowtie67
Bowtie67's Avatar
Someone had posted in the Engine drivetrain forum on info relating to automatic vs maual chokes. I did a little write up on how to setup an auto choke.
http://67-72chevytrucks.com/vboard/s...d.php?t=191753
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 03-08-2006, 08:01 AM   #5
byrd
Union Electrician
byrd's Avatar
Are you sure you have the right sendin unit in the blazer tank? There are two that I know of 30 ohm for 63-66 and thee 90 ohm 67-72 . If you have the right sending unit, then your resistor on the back of the fuel gauge is probably worn out.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 03-08-2006, 09:22 AM   #6
72MARIO
72MARIO's Avatar
There is no reason you could not get the choke to work. It's just time setting it one click at a time. Call Bary Grant and tell them what your problems are with the choke they have a great tec line.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
