03-05-2006, 09:39 AM | #1 |
Weird chirping noise. What is it?
When I drive my 86, I occasionally have a wierd pulsating, chirping sound coming from the dash. It speeds up as the truck speeds up and slows down as the truck does. My first thought was the speedo or cable. The speedo doesn't jump or bobble at any speed. Would the speedo cable just be dry on the inside or what?
03-05-2006, 11:20 AM | #2 |
yeller
Re: Weird chirping noise. What is it?
Matt, that would be my first guess...pull it and see what you find out.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
03-05-2006, 01:32 PM | #3 |
What do we get for $10?
Sounds like the culprit to me too.
My 'Burb that I just got had MAJOR chirping.
1977 GMC K25 400/400/205 1989 Chevy Suburban R1500 350/700R4 (work beater) 1994 Chevy K3500 dually 454/4L80 1996 Corvette LT4 350/ZF 6 speed 2000 Bonneville SSEI Supercharged 3.8 Liter V6 1966 Chevelle 2 door sedan (Needs major repair ) Last edited by 77gmcjoe; 03-05-2006 at 01:34 PM. |
03-05-2006, 06:20 PM | #4 |
sounds like speedo., but I don't know whether it would be the cable or the actual speed display gauge. Mine sounds like a scratching noise when it is cold outside. I am kind of watching to see what others say about it.
03-05-2006, 07:49 PM | #5 |
Right turn Clyde
Pull the cable out and lube it. Just takes a little time and effort. Could also be that the speedometer cable tube is worn out from rubbing and the cable not lubed.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
03-05-2006, 11:33 PM | #6 |
It doesn't make any noise when it's cold. It seems to be after it warms up a little. i'll try to checkit out this week.
03-06-2006, 10:33 AM | #7 |
Insert Witty Text Here
I have the same problem. I assume it is a dry cable, but I have not tried to fix it yet. The sound is only annoying, and I am usually too busy fixing stuff that is actually broken to work on things that are only annoying.
Slonaker |
