Adapter ?
If I use a 1405 Edelbrock Performer Carburetor Square Bore
with my stock 350 manifold should I use the adapter with 4 holes or the one with one large hole? Thanks in advance
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html |
![]() ![]() Join Date: Jan 2005
Re: Adapter ?
Mr. Gasket sells adapters. They list part number 1932 for mounting a Carter AFB (Edelbrock Performer) to a Quadrajet Spreadbore manifold, and it has four holes.
http://go.mrgasket.com/pdf/carb_fuel_sys_acc.pdf Last edited by pjmoreland; 03-05-2006 at 08:54 PM. |
Re: Adapter ?
Thank You.
That's just the info I needed.
