Old 03-05-2006, 08:22 PM   #1
chucks70
BB air cleaner = SB air cleaner
Wondering if an air cleaner for a BB 4 bbl is the same as one use on a 350 SB. Also, would the hear riser tube be the same?
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible.
chucks70 is offline   Reply With Quote
Old 03-05-2006, 08:46 PM   #2
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: BB air cleaner = SB air cleaner
Shoulb be the same. You might have hood clearance issues depending on your manifold. The heat riser tube is probably too short.
low'n slow is offline   Reply With Quote
Old 03-05-2006, 08:59 PM   #3
chucks70
My 350 will be basically stock set up with original manifold.
Old 03-05-2006, 09:06 PM   #4
low'n slow
low'n slow's Avatar
OOPs. I thought you were going the other way. I changed out the 350 in my 78 and went with a 396 with a factory hgh rise. I had to use the short air cleaner. I used the stock small block towers and mounts.
