Cause the Chicks DIG IT!!
Door hinges
I just got some new pins and bushings to replace the worn out ones currently on the hinges in my 71. I put the first pin in and it is about 1/2 inch longer than the old one that came out. I looked at the rest of the pins and they're all the same length. Has anybody ever had this problem before and if so will the pins still work? I'm thinking they will but it just looks kind of tacky.
Re: Door hinges
Cut 'em off with a whizz wheel (they should be hardened steel) before installing the rest.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
Re: Door hinges
Is that what you did on yours? or is that what you're recomending? If you cut them off before you put them in you loose the tapered portion of the pin which might give you fits when going to install them.
![]() Join Date: Jul 2004
Re: Door hinges
My set came that way also and I don't know why, they were from Chevy Duty if it matters, maybe they are all that way, don't know. Anyway we were able to cut it off with a regular hacksaw and then use a bench grinder to smooth up the end and put a taper back on. Not a show stopper, but turns a simple project into a slightly longer project, but don't all truck projects go that way ???
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
![]() ![]() Join Date: Jul 2002
Re: Door hinges
The pins fit a variety of truck models. They just made them for the largest size hinge. I put mine in, then used a cutoff wheel to shorten them.
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Door hinges
Like Bill said, if you cut them after the hinges are assembled, the tapered tip is inmaterial. That's how I do mine.
Re: Door hinges
I just did mine this past weekend. Used an air cutoff tool to take the extra length off. The pin kits I bought had nylon bushings....I went to NAPA and got the bronze bushings. WHAT a difference it makes to have new bushings and pins in my doors! It is really amazing.
Since I had more than one truck to replace the pins on, I bought a door removal and installation tool from Harbor Freight. This tool is only available from the online store. $79.99....best money I've spent in a while. I holds pretty much any type of door. Any board members that are close by and want to borrow it...let me know! ![]() http://www.harborfreight.com/cpi/cta...emnumber=40386
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
Re: Door hinges
sweet. Thanks for all the replies guys. I'll go ahead and cut em down then. I just didn't know if they all came like that or I had gotten the wrong ones by chance.
Re: Door hinges
Like Green Machine said... cut to length with a cut-off wheel and then taper with a bench grinder. Gives you a tapered pin just like stock.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
