Old 03-05-2006, 10:04 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Need some wheel cylinder help..
I have a eaton rear end that I need wheel cylinders for how come the parts store guys cannot help me out?? They all offer a rebuild kit for em I would really like to rebuild the rear brakes outta all new stuff not rebuilt stuff.. Cn anyone help me out here with a part# or year specific application(I have no idea what it came outta?) Any help in dealing with the parts counter guy would be great..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-05-2006, 10:09 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Need some wheel cylinder help..
You need to find a real good guy at a place liek NAPA, but be forwarned... it'll cost a LOT.
I replaced 3 brake cylinders, one set of shoes, all hdwr and adjusters, and front bearings and all seals.... and that cost me just shy of 500 bucks...with a discount.
My drum brakes on this truck will NEVER get new parts on them again... I have a little more time left, but the rear end will be replaced, and the front end will get a complete disc swap too.
Old 03-05-2006, 10:30 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
So what your saying andy is that I need to find someone who knows these old trucks or did the guy at napa have no problem finding the parts you needed???
MEMBER #6377
Project "7DEUCE"
Old 03-05-2006, 10:36 PM   #4
Longhorn Man
I shoulda finished my thoughts before hitting enter.
You need to find a guy who knows how to use the paper books, and knows his stuff.
My guy at NAPA knows his stuff... but it still took quite a bit of trial and error to get the right stuff. When you get an item in hand, inspect it very carefully and compair it to your parts. Meausements and stuff will be needed. Real PITA.
Old 03-05-2006, 11:03 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
Thanks andy I was hopeing someone would have part#'s but I guess I will try the napa monday....
MEMBER #6377
Project "7DEUCE"
Old 03-06-2006, 12:16 AM   #6
69k5
I used to have the numbers I'll look and see if I can find them. do a search at coloradok5.com i think i remember seeing them listed there. my eaton came out of a 72 K20 LWB. you will need to know if you have the big or little brakes. i mean 11 or 13 inch pads. it makes a difference. it cost to much on mine and I went to disc it was cheaper.
69k5 is offline   Reply With Quote
Old 03-06-2006, 12:25 AM   #7
69k5
heres a start this is from advance autoparts online store. they are the only people in monroe where i live that carried eaton parts. napa could order them but they cost a lot more.
Part No.
W49681 <http://www.partsamerica.com/images/spaclear.gif>
Tru Torque WHEEL CYL ASSEMBLY
New; Rear; Right; 1 1/8" Bore
Warranty: 1 Year Replacement Warranty
* Ships in 1 day
$26.96
Part No.
W49680 <http://www.partsamerica.com/images/spaclear.gif>
New; Rear; Left; 1 1/8" Bore
* Ships in 1 day
$26.96
Part No.
33532 <http://www.partsamerica.com/images/spaclear.gif>
Bendix Wheel Cylinder
Rear; Left or Right Match w/ Old Cylinder; 1 1/8"; w/11" Rear Brakes; (JB6)
* Ships in 1 day
$32.44
Part No.
33533 <http://www.partsamerica.com/images/spaclear.gif>
* Ships in 1 day
$32.44
Part No.
33501 <http://www.partsamerica.com/images/spaclear.gif>
Rear; Left or Right Match w/ Old Cylinder; 1 1/8"; w/13" Rear Brakes; (JB7)
* Ships in 1 day
$35.94
Part No.
33502 <http://www.partsamerica.com/images/spaclear.gif>
* Ships in 1 day
$35.94
Part No.
WC34474 <http://www.partsamerica.com/images/spaclear.gif>
Raybestos Wheel Cylinder: PG Plus?
Rear Left Wheel Cylinder: Pg Plus; Leaf Springs
Warranty: 3 Month Limited Warranty
* Ships in 1 day
$39.99
Part No.
WC34475 <http://www.partsamerica.com/images/spaclear.gif>
Rear Right Wheel Cylinder: Pg Plus; Leaf Springs
* Ships in 1 day
$39.99
Part No.
WC37039 <http://www.partsamerica.com/images/spaclear.gif>
Rear Right Wheel Cylinder: Pg Plus; Coil Springs
* Ships in 1 day
$47.99
Part No.
WC37040 <http://www.partsamerica.com/images/spaclear.gif>
Rear Left Wheel Cylinder: Pg Plus; Coil Springs
* Ships in 1 day
$41.99
Part No.
2037039 <http://www.partsamerica.com/images/spaclear.gif>
Raybestos Wheel Cylinder: Raymold
Rear Right Wheel Cylinder: Raymold; Coil Springs
* Ships in 1 day
$19.99
Part No.
2037040 <http://www.partsamerica.com/images/spaclear.gif>
Rear Left Wheel Cylinder: Raymold; Coil Springs
* Ships in 1 day
$19.99
Old 03-06-2006, 12:31 AM   #8
4x4Poet
If possible, take an old wheel cylinder in with you. The leaf and coil sprung Eatons used different wheel cylinders and do not interchange. Both are available because I've purchase both within the last few months. If the parts guy asks "leaf springs or coil springs," you know he's on track. Why not use a 71/72 K20 or C20?
Longhorn Man has a point. Compare all the prices involved with Blackbird's disc brake conversion kit cost. Or with just the caliper brackets plus locally sourced parts. Before sinking some dough into the drum brakes, caliper those drums to see if you'll be spending ~$130 for new drums to replace ones beyond max diameter. If the drums can be turned within max dia, then maybe the shoes, spring kits, adjuster kits, and wheel cylinders won't come close to a disc conversion– this time.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
