Old 03-05-2006, 10:16 PM   #1
Corellian Corvette
New owner of a ‘74 Cheyenne. Many Questions!
Hello everyone!
I picked up my first Chevy Truck yesterday, a 1974 Cheyenne. It has a 350 with a 4-bbl Quadrajet. 4WD with a 4 speed manual. So far it’s fun and runs well but it’s going to need a little work. I think I got a pretty good deal, too.
I’m not new to restoring/fixing up cars (I have several of the GM classics and even an old Mustang) but I’m new to the truck world. I have many questions (some random) so please bear with me! Thanks in advance for all the help.
First – can anyone explain the whole C/K/Suburban/Silverado/Blazer thing to me? Exactly what truck do I have? J I know it says Cheyenne on the side, but I’m not sure the differences between C/K and C10 vs. C20, etc. and some of the other things I see online. I quick course (or link to a good explanation) would be helpful so I know how to identify my vehicle at the NAPA counter J
Second – what’s the best place for restoration parts? I’ve seen the Classic Industries catalog, but there are some interior parts (like the 4 speed shifter boot for instance) that aren’t listed. Any other good parts sources?
Are assembly or shop manuals available for 74 trucks? That’s always my first purchase, but all I can find are the Chilton’s or Haynes Manuals. The previous owner didn’t do a terrible job hacking things up (that I can see), but I found a strange white plunger type doodad hanging from my clutch pedal and I sure would like to know what it is!
Is there a good online VIN/Trim tag decoder? The truck is blue with a blue interior but I see there are Dark Blue and Light blue parts available and I want to make sure I’m ordering the right stuff!
Is it possible/straightforward to get this truck a little lower to the ground? I don’t want it slammed, but it’s pretty tall and I’d like to bring it down a couple of inches. I assume it’s a simple leaf spring/shock absorber swap, but you know what happens when you assume J
The previous owner somehow managed to remove the ductwork to the side air vents. All the dash vents are there (it’s not an AC car) but I don’t see how to connect them? Is there a special piece needed or do I just get the flexible ductwork I see in the catalogs?
I’m nearly positive that the negative battery cable is attached in the wrong place (it’s attached to the adjusting bolt on top of the alternator). Where is the correct place to attach it to the engine?
If anyone has really good pictures of an original 74 engine compartment (from all angles) it would be EXTREMELY helpful! There is some wiring stuff going on there that I would like to figure out.
Thanks again!
Corellian Corvette is offline   Reply With Quote
Old 03-05-2006, 10:48 PM   #2
Cooter007
Re: New owner of a ‘74 Cheyenne. Many Questions!
I’m new here myself but I will tell you the little bit I know!
VIN ... http://www.73-87chevytrucks.com/VIN.htm
Parts
http://www.classicindustries.com/
http://www.chevyduty.com/
http://www.lmctruck.com/ .. I have ordered from them twice without any problems.
1974 K10 StepSide 350/350
Cooter007 is offline   Reply With Quote
Old 03-05-2006, 11:59 PM   #3
bigblock73
yeller
bigblock73's Avatar
C=2 wheel drive, K= 4 wheel drive. 10=1/2 ton suspension, 20=3/4 ton suspension, and 30=1 ton suspension.
I try to always buy GM parts, either off Ebay, from GM, from this board, or from restoration parts companies. Check out this links page on my site for a pretty good assortment.
http://www.73-87.com/links/trklinks.htm
I am not aware of any place that sells them, but I do see them on Ebay from time to time.
http://www.73-87.com/chevy_ids/sbcid2.htm
http://www.73-87.com/7387info/7387info.htm
I suppose you could remove a leaf or two from your springs to drop the truck, but it isn't all that common to do on a 4wd...you might want to rethink this?
Anyhow, hope this helps some. You could also drop by the site in my signature, tons of info on 73-87 trucks..more than likely you will find what you are looking for there.
Welcome to the board from Minnesota!
bigblock73 is offline   Reply With Quote
Old 03-06-2006, 10:31 AM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I bought my factory shop manuals (3 volumes) from www.helminc.com. You might check and see if they have a set for yours.
I doubt there is much you can do to lower it unless it has been lifted or has oversized tires. If that is the case, you can probably undo what has been done and drop it back down to stock.
Post pics. We like pictures!
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
