Old 03-06-2006, 10:02 AM   #1
dennislbrooks
dennislbrooks's Avatar
front sway bar --66 1/2 ton
Do the lower a-arms have the 2 holes for the bushing bracket mounts for front sway bars? And does the frame have the front mount holes in place. In other words am I going to have to drill?
dennislbrooks is offline   Reply With Quote
Old 03-06-2006, 03:49 PM   #2
dallas71
dallas71's Avatar
Re: front sway bar --66 1/2 ton
the holes are already there no drilling necessary....
dallas71 is offline   Reply With Quote
Old 03-06-2006, 06:29 PM   #3
dennislbrooks
thanks
Old 03-07-2006, 11:08 AM   #4
BobS
BobS's Avatar
Dennis,
Which frame mounts are you using?
Bob
V-6....only GMC Trucks have it!
62 GMC W5000 NAPCO-V6
65 GMC 2500 NAPCO Panel-V6
66 GMC 1000-V6
66 GMC 1500-V6
67 GMC K1500-SBC (originally a KM-V6)
68 GMC C1500-V6
68 GMC C1500-V6
68 GMC Suburban C2500
70 Chevy K20-SBC
71 Chevy C30 Longhorn-SBC
72 GMC Suburban C1500-BBC
72 Chevy C10-SBC
72 GMC C5500-ToroFlow Diesel
BobS is offline   Reply With Quote
Old 03-07-2006, 03:11 PM   #5
dennislbrooks
Not sure---whatever I get from TX Firefighter. Do you have a suggestion?
Old 03-07-2006, 03:42 PM   #6
BobS
BobS's Avatar
No, I'm just curious as to whether the frame mounts from a 66 and earlier are the same as 67 and later. It doesn't look like they would be the same but I'm not sure. I have a bar and mounts from a 68 that I'm going to put on a 66 after I get the crossmember swapped out. I think the 68 mounts will work but the 66 mounts are probably different. Got any pics?
Bob
66 GMC 1000-V6
66 GMC 1500-V6
68 GMC C1500-V6
68 GMC C1500-V6
70 Chevy K20-SBC
72 Chevy C10-SBC
Old 03-07-2006, 05:05 PM   #7
dennislbrooks
No not yet, my friend has a 66, I have a 67 --- I make comparisons to see what is the same. As you know the 66 and 67-72 suspension is near if not the same. We put 72 spindles and disc on his 66 just like on my 67. Next is a front sway bar. Will send pics if I get done before you but probably will be 4 to 6 weeks. I still have to pick up the sway bar and mounts from TX Firefighter. Only thing I would have a pic of is my 67 with sway bar.
Looks like you may need another GMC. 8-)
Old 03-07-2006, 11:01 PM   #8
BobS
BobS's Avatar
The front crossmembers are different and the sway bar mount on a 67-later uses the same rivet as the crossmember. I haven't seen the mounts on a 66.
Every so often another one just follows me home, I have no control over it!
Bob
66 GMC 1000-V6
66 GMC 1500-V6
68 GMC C1500-V6
68 GMC C1500-V6
70 Chevy K20-SBC
72 Chevy C10-SBC
