Old 03-06-2006, 01:13 PM   #1
Huskerboy2
Starter/Ignition Run On
Once in awhile, when I go to start my 1 ton, it's like the starter gets stuck. The truck continues to crank and you can't turn it off. Even after I turn the key off, the truck is still trying to turn over. Any ideas? Starter? Ignition? Thanks all.
'72 Chevy Blazer
Huskerboy2 is offline   Reply With Quote
Old 03-06-2006, 03:33 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Starter/Ignition Run On
Probably need to shim the starter.
Old 03-06-2006, 03:44 PM   #3
dennislbrooks
dennislbrooks's Avatar
yes agree - one shim should do it
dennislbrooks is offline   Reply With Quote
Old 03-06-2006, 04:09 PM   #4
Huskerboy2
Thanks for the replies guys. I'm going to sound like an idiot here, but it wouldn't be the first time. Can you elaborate a little more on shimming the starter. Can you buy a starter shim at Autozone, etc.? What does shimming do exactly? Thanks again.
'72 Chevy Blazer
Old 03-06-2006, 04:40 PM   #5
jhow66
jhow66's Avatar
Did you just change starters?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-06-2006, 04:46 PM   #6
Huskerboy2
No, but I just recently bought the truck. The previous owner had the same problem with it. He told me about it. I figured worse case, it needed a new starter.
'72 Chevy Blazer
Old 03-06-2006, 05:01 PM   #7
jbon64
jbon64's Avatar
shimming a starter moves the gear away from the flywheel . if there is not enough clearance between the flywheel and the gear on the starter it wont retract after you let off the key. if the problem is still there after shimming , you will most likely need a new starter
hey.....smell my finger
64 nova wagon , 63 nova convertible
jbon64 is offline   Reply With Quote
Old 03-06-2006, 05:14 PM   #8
jhow66
jhow66's Avatar
Spring in starter selenoid could be broke also..
Old 03-08-2006, 05:54 AM   #9
71-longbed
Its Magically Delicious
71-longbed's Avatar
also check the ignition switch ... i had a similar problem and replacing the switch stopped it
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 03-08-2006, 09:31 AM   #10
bagged74
its just $$$$$
bagged74's Avatar
my guess would be the starter solenoid. I bought a brand new starter for my 86 and when i put it on I had this same problem. I had to take the solenoid apart and put it back to gether the right way.
bagged74 is offline   Reply With Quote
Old 03-08-2006, 10:59 AM   #11
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
There is a big round disk in the back of the soleniod that makes contact between the two terminals(battery-starter)this will stick or weld to the contacts causing the starter to stay engaged. Replace your soleniod should solve your problem.
sneakysnake is offline   Reply With Quote
