Old 03-06-2006, 03:18 PM   #1
Myself
What's NF on crankshaft mean?
I'm sending out the parts to start the rebuild on my wife's 350. Just wondering what the NF on the crank stood for.
Myself is offline   Reply With Quote
Old 03-06-2006, 09:17 PM   #2
Re: What's NF on crankshaft mean?
Try asking in the engines section if you don`t get an answer here.
Old 03-06-2006, 11:44 PM   #3
crazy longhorn
Fabricate till you "puke"
Oh crap, you had to ask......you will no doubt get several answers. I have seen many replies.......some say nodular ferris (iron), some say that all the cranks are nodular(cast steel),& the mark, or letters you see are a foundary mark? On the cast cranks, they are ALL cast steel......that leaves the mark to be from the foundary. In the case of the big bad Olds, the capital N is said to be the 1st choice, or a little cn as a good 2nd choice? Sooo... Me thinks its a casting mark L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-07-2006, 01:47 PM   #4
wibilly
wibilly's Avatar
Andy i here that that N is the case with Pontiacs also. Any truth to that
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-07-2006, 01:56 PM   #5
KCW
1972 GMC 2006 GMC
KCW's Avatar
NF = Not Ford.......?? Thank goodness
KCW is offline   Reply With Quote
