Life is a gamble
TH350 leak
I've got a leak on my transmission, that is not slow anymore. Its leaking BAD!
I've never done any work with transmissions and wanted to see what everyone thinks is the best way to attack this problem. The below picture should show my leak. ![]() Thanks ACES
1970 Orange CST C-10 w/350, posi, Longbed The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine. -- Ralph Waldo Emerson |
Re: TH350 leak
replace that line with a single piece....looks like the compression union is leaking....
Life is a gamble
Re: TH350 leak
Thanks dallas71, Do you know what that "single piece" is called? So the guy at the parts store knows what I'm talking about.
Life is a gamble
Re: TH350 leak
nevermind, Transmission Cooler lines right?
its all about the +6 inches
Re: TH350 leak
you tried tightening the fittings?
Personally, I like the fittings liek that, it makes it easier to drop the tranny. |
Life is a gamble
Re: TH350 leak
Yeah, I tried tightening it. It only made the leak worse. A LOT worse!
Active Member
![]() Join Date: May 2005
Re: TH350 leak
flare on the inside of the fitting may be cracked, thus tightening would make it worse. Pull it apart and take a look at the flare/lines.
Jason ________ VAAAPP Last edited by Jayss109; 04-27-2011 at 11:36 PM. |
member #16
![]() Join Date: Dec 1999
Re: TH350 leak
The compression union will have 5/16 ferrules. You can cut the line with a tubing cutter and replace the union. I would use new fitting in case the old one has bad threads. The best way is still to install a new line. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Designated A-hole!
Re: TH350 leak
Just buy preflared fuel lines in the correct size/length. You can use stiff wire to mock it up and determine the length you need.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
