Old 03-06-2006, 08:41 PM   #1
1969k10stepside
lift kit
hi i have a 69 k10 and i want to put a lift kit on it. the previous owner has swapped out one of the rear leaf springs with a different one and the truck sits crooked so i will need to get new leaf springs all the way around. what lift kits are available in 4-6 inches.
1969k10stepside is offline   Reply With Quote
Old 03-06-2006, 08:45 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: lift kit
I use Tuff Country front springs and a shackle flip in back. Check out www.offroaddesign.com for front and rear Tuff Country springs. You will also need an adjustable drag link if you still have the closed knuckle front axle. The dropped pitman arm won't work. You might have to change to a cv-joint for your front axle. I had to on my 69 K20. It has a Rockwell T221 transfer case.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 03-06-2006, 10:08 PM   #3
see ten
WTB this ad
see ten's Avatar
Re: lift kit
I have a 4" Skyjacker with front and rear springs.
see ten is offline   Reply With Quote
Old 03-06-2006, 10:12 PM   #4
1971ChevyTruck
1971ChevyTruck's Avatar
Re: lift kit
I used Rancho spring for a 73-87 truck on the front and ordered new leaf springs from jc whitney with 6" blocks on thw back
1971ChevyTruck is offline   Reply With Quote
