03-06-2006, 10:46 PM | #1 |
Old member
Heater Fan Motor
I know this has been asked quit a few times but I have started taking the A/C out of my truck to fix the heater core. I remember a long time back some people where saying you could put a different fan motor in place of the stock to blow more air. Does anybody have the info and could you post it please. Thanks.
03-07-2006, 12:39 AM | #2 |
Re: Heater Fan Motor
I've heard of installing an A/C fan motor in a non-A/C heater box. Nothing about upgrading an A/C fan comes to mind. In any case, bump for you.
I think the world needs a drink... Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
03-07-2006, 06:51 AM | #3 |
The AC fan usually moves a lot of air and if you are having low air flow there could be other problems. The vanes on the fan deteriorate over time and there is always a chance of leaves and debris building up inside the ducts. If the motor does not have a good ground it will run slow or it could be defective. The relay and wiring should be checked, also.
You will want to make sure that the door in the air switch box is working properly. Jim |
03-07-2006, 07:27 AM | #4 |
Old member
Thanks guy's, no problem with the fan, just thought since I had to take it apart for the heater core a might as well change out the fan also. I thought it was a swap for the A/C motor. It must just be for the regular heater box.
03-07-2006, 01:42 PM | #5 |
andy i read somthing on here about that too. i think it was mid 90's blower moter. maby it was just for non air trucks mine has air too and i thought while it is apart i would upgrade as well
common sense isn't so common anymore |
03-07-2006, 02:21 PM | #6 |
Old member
OK back to the orignal ? then is there a upgrade for our trucks. I thought I remember it being a caddy fan. I don't remember it that well though. Anybody have any idea's.
03-07-2006, 04:38 PM | #7 |
not sure about fan upgrade.... I seem to recall something about a caddy fan also but don't remeber if it was for ac or non-ac. There's a great write up in the faq section on replacing a non AC h. core..... how about a write up (photos?) for faq on an AC heater core replacement?
03-07-2006, 04:58 PM | #8 |
AFAIK, Classic Auto Air, Vintage Air, and Old Air all claim that their aftermarket 67-72 systems come with fan motors that move more air than stock. Maybe they offer oem replacement fan motors.
To save some $$, I would prefer to find the application for a superior than oem fan motor, so btt.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
03-07-2006, 06:09 PM | #9 |
just cleaning out 35years of crap in the heater housing will give you lots more air flow
03-07-2006, 06:42 PM | #10 |
saving one more
on my 72, the piece that goes on the fan motor shaft was spinning inside the blower wheel, it was supposed to be firmly attached to the blower wheel, but was spinning almost freely, I had a very loud squeal and very little airflow, I bought a new fan motor and replaced it, come to find out, just the blower wheel itself was bad. I have plenty of airflow now.
just grab the fan motor shaft in one hand and the blower wheel in the other, the wheel obiously shouldn't turn with the shaft being held Just a thought
72 Chevy longbed - now for parts 69 Chevy short fleet - needing some love 70 RS Camaro - needing more love driver - 96 GMC X-cab |
03-07-2006, 06:46 PM | #11 |
Here ya go (again X 2):
http://67-72chevytrucks.com/vboard/s...d.php?t=166446 I have it bookmarked because I aim to do this as well.
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
03-07-2006, 09:13 PM | #12 |
Short, Fleet, Slammed, V8 Club
I have the Hypercool Air/Heat/Defrost system in my truck. This thing blows more air on medium than my 03 Dodge blows on high.
03-08-2006, 01:51 PM | #13 |
Old member
Ok so a blower out of a 94 chevy extended cab will work and give more air flow. Thanks roger0800 for the link. I will check on this.
Sorry about the after thought of pictures, but I was getting my truck ready for a month long trip next week. Monday I will be out of town working so I need to get this done so I can take it and have it charged back up.
