Old 03-07-2006, 01:01 AM   #1
Corellian Corvette
Question about Temp Gage - where should it rest normally?
Hey everyone!
Question - For all you owners with functional gages - where should the temp gage rest when the truck is at operating temp?
Here's the story:
Pulled the cluster out tonight to rebuild. When I got the truck the the stock temp gage was pegged and the P.O. had installed an aftermarket one.
I knew the problem was likely a grounded wire somewhere and sure enough the little metal tabs on the back were really loose.
Got it all re-assembled and back in tonight and it's nice to have full lights and functional signals again!
Now, the gage seems to be working (at least it rests at C instead of off the chart) - but I'm wondering if it's working correctly. There is a 195deg thermostat, and the aftermarket gage rests right at 195. So that appears to be right. However, the dash gage comes to rest at about the 1/4 mark past C. I was assuming the right resting place would be about 1/2 way.
If 195 should be 1/2 way, how would I go about fixing it?
Thanks!
Corellian Corvette is offline   Reply With Quote
Old 03-07-2006, 01:52 AM   #2
cliffsta
Stepsides RULE
cliffsta's Avatar
Re: Question about Temp Gage - where should it rest normally?
mine rests right above the 1/4 mark at operating temp assuming it's not extremely cold or hot outside.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 03-07-2006, 03:10 PM   #3
Prerunner1982
Prerunner1982's Avatar
i agree, both of my trucks rest at or just aboe the first tick.. or 1/4 mark...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 03-07-2006, 09:43 PM   #4
Corellian Corvette
Good news then! Sounds like it's working. I assume you guys are also running stock thermostats?
Thanks!
Old 03-07-2006, 10:05 PM   #5
RUST
RUST's Avatar
Yeap! 1/4 mark with 195 thermo
RUST is offline   Reply With Quote
Old 03-07-2006, 10:15 PM   #6
jermasaurus
jermasaurus's Avatar
Mine is right by the middle at operating temperature. with a 195 thermostat.
I had a 160 in it before and it was right about where you guys are saying.
jeremy
79 Jimmy slammed AKA James Down
jermasaurus is offline   Reply With Quote
Old 03-08-2006, 02:04 AM   #7
Russell
Professional Grade
Russell's Avatar
If you've got a newer sending unit with an older gauge, it will just barely come off the C, but if you've got a newer gauge with an older sending unit, it'll sit at about half way.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-08-2006, 02:10 AM   #8
Corellian Corvette
Judging by this car - it's the original sending unit and I'm pretty sure the original gauge.
