03-07-2006, 01:40 AM | #1 |
Bolt index
Given that I'm probably like most here that like to tear into their trucks, fix things, make things nice; I need some help. I have a problem of misplacing bolts and was wondering if there is a master of all that knows what bolts are what, size, replacements, etc. Currently, I'm trying to get my inspection cover back on but don't have any of the bolts to do so.
Jimmie Modern Vintage Autoworks - '70 Chevy C10 - '74 Chevy C30 3+3 Dually - '04 Chevy Colorado Built, NOT, Bought. If you build it...they will ENVY! Drive Slow, Scrape Hard, or Take Your Truck and GO HOME! |
03-07-2006, 02:08 PM | #2 |
Questionable
Re: Bolt index
ttt
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
03-08-2006, 12:31 PM | #3 |
It's a catastrophic success.
Re: Bolt index
The bolts should all be (SAE) 1/4-5/16-3/8-7/16-1/2-5/8ths. the trick is to measure the depth to determine the length of bolt you will need.
http://www.sizes.com/tools/thread_American.htm |
03-08-2006, 06:22 PM | #4 |
Cantankerous Geezer
Re: Bolt index
Best thing to do is steal a bunch of sandwich bags out of the kitchen. Take a pen and index cards and write down where the bolts came from, draw a picture if it helps. Then put the bolts and card in the bag and zip it shut. Put the bags in a box and mark the box with what's in it.
Then when you go to put things back together you only have to find the box. Or you can do what I did. Buy a bolt kit from Totally Stainless. The bolts are all in labeled packages.
Fred There is no such thing as too much cam...just not enough engine. |
03-08-2006, 10:20 PM | #5 |
Re: Bolt index
absolutely---ziplock is your friend
03-08-2006, 10:47 PM | #6 |
Re: Bolt index
with everyone. A handy tool is a thread gauge - if you're not sure what the bolt is then you can just put this in the hole and find the exact thread. I have a drawer with the "standard" sizes noted previously as well - I just bring 'em over and find the right one
