Old 03-07-2006, 05:11 AM   #1
karl
karl's Avatar
sagging doors
both of the doors on my 77 half are at least a half inch low. do i need to replace all the hinges or?? also the passenger door dosent latch and the door seems to fly open. not good. any ideas on how to fix this?? thanks.
karl is offline   Reply With Quote
Old 03-07-2006, 08:37 AM   #2
beaterC10
Re: sagging doors
You need to either replace the hinges or replace the bushings and pins, that should also help with the door latching.
beaterC10 is offline   Reply With Quote
Old 03-07-2006, 01:08 PM   #3
tgh117
Crazy
tgh117's Avatar
Re: sagging doors
I agree with beater, going to need to change the bushings and pins or the hinges. You may also need to replace the striker on the passenger side, depending on if the hinges help your problem or not. There is a piece of plastic around the steel part of the striker that will wear out and break, which causes the latch to not grab the striker as well. If the hinges don't solve your problem for that door complete, you can pick up a new stiker at autozone or anywhere pretty much for like 5 bucks. Good luck.
77 SB Stepside in a bunch of pieces scattered around the garage.
tgh117 is offline   Reply With Quote
Old 03-07-2006, 07:09 PM   #4
evan
evan's Avatar
Re: sagging doors
There is an article about this topic in the May issue of "Classic Trucks".
Evan B.
evan is offline   Reply With Quote
