Old 03-07-2006, 08:13 PM   #1
hotrodhomi
hotrodhomi's Avatar
pressure info needed
When performing a cylinder pressure test. How low is too low? I know that if one cylinder has a lower pressure than the other s that it indicates a problem. But what should the pressures be? 350 motor stock bore/ heads.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 03-07-2006, 09:32 PM   #2
hotrodhomi
hotrodhomi's Avatar
Re: pressure info needed
I'm just looking for a range. I know that compression ratios changed a little through out the years. The block is on a 72 blazer- all stock
'66 impala ht
Old 03-08-2006, 12:31 AM   #3
QKENUF4U
QKENUF4U's Avatar
150psi+(just a guess on my part) with less than 10% difference in cylinders
QKENUF4U is offline   Reply With Quote
Old 03-08-2006, 12:03 PM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
The main thing is consistency,unless its smoking like a freight train and the rings are shot then check for a closeness between cylinders.Ratios and pressures will vary between engines but shouldnt fluxuate much between cylinders unless theres a problem.
sneakysnake is offline   Reply With Quote
