C10 Club Tennessee
700r4 Speedometer with 20's
Hey guys,
How can I get my speedometer on my new 700r4 to read correct with my 20's. I have a mechanical speedometer, so I'm not sure if I'm just going to be stuck without a speedometer or not.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
Re: 700r4 Speedometer with 20's
talk to a tranny shop they can either give you the right gear or you can also get an add on gear box to step up or down to correct it
C10 Club Tennessee
I talked to the tranny shop and he didn't seem to know how. I figured somebody on here would have had this problem and fixed it.
![]() ![]() Join Date: Jan 2005
Does your transmission have an electric speedometer output right now? If so, you'll need to replace the speedometer output with a gear style. You'll need the drive gear that mounts to the transmission output shaft, the driven gear that the speedometer cable connects to, and the housing that holds the driven gear (three sizes available depending on the driven gear size).
http://www.73-87.com/7387garage/drivetrain/spdgears.htm http://www.73-87.com/7387garage/drivetrain/speedo.htm http://www.tciauto.com/tech_info/speedo_gears.htm Last edited by pjmoreland; 03-07-2006 at 11:24 PM. |
What size are your rear tires? What rear end gears do you have?
C10 Club Tennessee
I have the mechanical speedometer
Also my rear tires are 275/45/20 with 4.11 gears
Factory or aftermarket guage? I know Autometer sells different ratio drives for their mech speedos.
Mike
Mike Redpath |
The TCI website indicates that your tire diameter is 29.74". TCI also indicates that with a 15-tooth driving gear, you'd need a 41.765 driven gear, so A 15-tooth (gray) driving gear and a 42-tooth (green) driven gear is the closest you'll get. You'll also need the driven gear housing for 40-45 tooth gears if you don't already have that one.
Here are the GM part numbers: 15-tooth (gray) driving gear = 8642620 (TCI 880018) 42-tooth (green) driven gear = 1362049 (TCI 880030) 40-45 Housing = 25512339 (TCI 880023) If your housing has 40 41 42 43 on the side of it, then it should work fine. Last edited by pjmoreland; 03-08-2006 at 04:02 PM. |
C10 Club Tennessee
I'm going to go pic up the tranny on tomorrow. I'll probably understand a little more when I see it. Tranny's aren't my thing. I the kind of guy that needs to be looking at it or have pics.
It looks like it's going to be around $40 for the three gears.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 03-08-2006 at 04:32 PM. |
#10 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
As long as you have the proper housing for your gears, price is cheap. The housing is a little over 20 bucks if I remember correctly. Yours will be labeled as to which gears it's for.
C10 Club Tennessee
Okay, here's what I pulled out of the tranny.
Which one needs to be replaced? Also this spring came out also, I can't figure out where it came from or if it was accidentally in there. GO FIGURE!!
1FINE69
I believe he stated that both the gears need replacing in order to get the correct reading fro your gauge. Spring ??????
Had a 69 swb fleetside 350zz3 w 400turbo trans oak lined bed with rhino coated sides red exterior. SOLD |
#13 |
C10 Club Tennessee
Just wanting to make sure these are the right ones:
http://www.powerandperformancenews.c...Category_Code= http://www.powerandperformancenews.c...Category_Code=
