03-08-2006, 05:02 AM | #1 |
Inner and outer rockers
Hello to all I'm new here. Have a question about the inner rocker panel. Is it the piece thats part of the floor or is it in addition the the piece thats off the floor. I bought all the patch panels and am not quite sure if its a add on or if I cut out the vertical piece that is attached to the floor and weld this one in. Thanks.
03-08-2006, 10:11 AM | #2 |
Short, Fleet, Slammed, V8 Club
Re: Inner and outer rockers
Welcome aboard from TN. Sorry I can't help you with your question though. Someone will be along shortly to answer you.
03-08-2006, 10:39 AM | #3 |
Chance
The inner rocker panel can either be a piece that you can buy separate or it comes as part of the floor if you buy front & rear outer floor patch panels. Go here: http://www.gmcpauls.com/Patch%20Panels.htm
Inner Rocker Backing Plate 132275 Quality At its Best Used Outside The Inner Rocker To Properly Join The Outer Floor To The Outer Rocker Panel Which Closes Off the Back Side Off the Outer Rocker. Not required if front & rear outer floor patch panels are used. $12.95
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
03-08-2006, 04:24 PM | #4 |
That is exactlt what I needed, Thanks!
