03-08-2006, 12:39 PM | #1 |
Where to buy..rear leaf spring bushings?
Replacing bushings on rear leaf springs on my 72 2wd 1/2 ton. Wheres the best place to buy from on these?
03-08-2006, 01:00 PM | #2 |
Re: Where to buy..rear leaf spring bushings?
any auto parts store in the usa
03-08-2006, 11:25 PM | #3 |
Actually you can not buy them at any auto parts in the US not Tennessee anyway! When I restored my truck I took mine out but never did find them for a 2wd just 4wd is all I could fine. ended up using drop leafs so I quit looking. Sorry not much help you might try a spring shop.
03-09-2006, 02:47 AM | #4 |
Not a bad nut after all..
Not to hijack the post, but where can a person get U-bolts for the same?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
03-09-2006, 03:21 AM | #5 |
This Prothane retailer seems to have rear 2wd spring bushings for 67-72s:
http://www.prothanesuspension.com/chevytruck.htm Compare your bushing OD specs with the chart. I noticed either 1-1/2" or 1-3/8" applied to shackle frame bushing OD. HTH.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
03-09-2006, 06:54 AM | #6 |
Watch out for your cornhole !
My local spring shop sells them. Ten dollars each, installed.
badpeanut, same place for the u-bolts, look in the phone book under "spring shops".
03-09-2006, 08:54 AM | #7 |
Keep On Truckin'
Spring and axle shop here sells them for $10 ea. installed as well.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
03-09-2006, 09:19 AM | #8 | |
Orange '71 GMC |
03-09-2006, 11:54 AM | #9 |
PST sells urethane bushings and reasonable as well. I just bought the rear control arm bushings for $20 to my door. I plan to get a full set for the 4X4 Blazer as well. Just measure the ID of the spring and you'll get em.
