Who has a Hedit's front end & where's the
Who has this front end? Do any of you run the manual rack and is it easy to steer? Or do you run the power steering rack?
Who has the cheapest price for one? $2500 is a bunch of cash to spend on one. I'm not real worried about air bags. |
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
Re: Who has a Hedit's front end & where's the
David, Did ya give up on the Malibu frame swap?
Active Member
![]() Join Date: Feb 2000
I put a Heidt's front crossmember in my first 53 pickup. I used junkyard stang II components ( no airbags, no tubular a- arms) I used he manual steering rack and it was fine. A guy I knew at the time who built afew of our trucks said I might not like the power rack because "its like the early Chrysler products, just atoo easy to turn the wheel". But maybe that what you want.
hope this helps. take it easy
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi |
#4 | |
I have the hedit's front end on my 55. With power steering, tubular a-arms and shockwave air suspension all around. I learned the hard way about the GM power steering pump pressure and the Ford power rack are not compatable. The ford rack needs about 700-900 PSI to run and the GM pump puts out 1300 - 1350 PSI. Borgeson sells shims for the GM pump to decrease the pressure.
I'm thinking about taking the power off the 55. just to get rid of the pump, reservois and the belt. I also have the hedit's 4 bar rear suspension, that is a real nice fit and works great. Noticed the difference over the leaf springs immediately!
1955 Chevy Series 1 |
![]() Join Date: May 2004
I believe RBs Obsolete in Glendale, AZ also sells a valve that bolts onto the PS pump to limit the pressure to solve this problem...
David, I just got through installing my Heidts front end.I got 2 in dropped spindles and manual rack and tubular upper and lowers for air ride.Also comes with swa bar.1625.00. I got mine from Rodparts Wharehouse. Took 2 weeks to get here.Right now the setup is sitting my crossmember on the ground.If someone can tell me how to attach pics I will do so.
Corey |
Hey Corey,
If my pm didnt help or if the pics are too big, you can email them to me and I will resize them and attach them. dennyb56@hotmail.com Let me know there coming just incase they get dumped in my spam folder Denny |
Yeah denny your e-mail helped.Now we will see if I can do my part.
Heres mine minus the cups/bags brakes and swaybar all of that is still sitting on shelf. |
Great job Corey, the chassis is coming along nicely!
Do you have anymore updates on your Heidt suspension, I am looking at there product for my 53 Chevy P/U.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
![]() Join Date: Apr 2005
I'm running a Heidts front crossmember with stock upper and lower control arms, stock spindles and a power rack (using a GM type 2 ?? pump with remote resevoir) on my 1948. Steering is a little touchy, but not to bad. Check my link 1948 below.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
