03-08-2006, 06:54 PM | #1 |
Gone Fishing
Fuel gauge no worky
I have had a problem with my fuel gauge for sometime now. I decided to try to fix it. The gauge never moves at all. The wire to the tank is good. Could it be the resistor on the gauge? if so where can I get the resistor. All help will be appreciated. Just tired of never knowing how much gas is left in the tank.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
03-09-2006, 11:20 AM | #2 |
Gone Fishing
Re: Fuel gauge no worky
I have removed the wire from the sending unit and no change in the gauge. It also never changes when I disconect the wire from the fuse block. This thing use o work. Please help.
03-09-2006, 12:19 PM | #3 |
C10 Club Tennessee
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
03-09-2006, 12:30 PM | #4 | |||
Union Electrician
I would ground out the wire from the sending unit to the gauge(brown iirc) and see if the gauge reads way past full or moves at all(that checks, and tests wiring and gauge), if so sending unit is most likely bad. if nothing then try the resistor Bryan mentioned above. Longhorn should chime in soon he just went through thiss not long ago. Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
03-09-2006, 01:54 PM | #5 |
C10 Club Tennessee
Listen to whatever Byrd tells you. He helped me fix mine after 2 months of screwing with it.
