Old 03-08-2006, 08:10 PM   #1
1969K10
1969K10's Avatar
drum 2 disk conversion
OK, so I'm entertaining the idea of taking the disk/drum set up from my wrecked '72-1/2 and installing it on a '68-1/2. the main reason is for the disk brakes up front.
1) Up front, can i just pull everything from the A-arms to the brakes off of the 72, and bolt them up to the '68?
2) If question #1 works, I don't want 5 lug up front & 6 lug out back... So, if both axles are 12-bolts, can I pull the axle shafts out of the '72 and install them in the '68? The '72 is leaf, and the '68 is coil...
1969K10 is offline   Reply With Quote
Old 03-08-2006, 08:33 PM   #2
qksilver
Re: drum 2 disk conversion
yes, no
qksilver is offline   Reply With Quote
Old 03-08-2006, 09:08 PM   #3
1969K10
1969K10's Avatar
what will cause problems with the rear?
Old 03-08-2006, 10:06 PM   #4
el curioso
el curioso's Avatar
The rear 72 axle is 3/4" wider than the 68 i had to fab up some spacer to make every thing line up brake wise.
el curioso is offline   Reply With Quote
