03-08-2006, 09:38 PM | #1 |
Removing Side windows??? ANY TRICKS?
I'm trying to pull my side windows out, any tricks to this? I've been messing with it for a little while, so any input will help! Thanks.
03-08-2006, 10:43 PM | #2 |
Re: Removing Side windows??? ANY TRICKS?
My Haynes manual says:
1. Lower the glass completely, remove the window regulator handle and the door lock knob. 2. Remove the door armrest and trim panel. 3. Remove the ventilator assembly as described in the preceding Section. 4. Slide the main window glass forward untill the front roller is in alignment with the notch in the sash channel. Disengage the roller. 5. Push the window forward and tilt the front edge up until the rear roller is disengaged. 6. Return the widow glass to the level position and withdraw it from the door. 7. If necessary, remove the mounting screws and withdraw the regulator assembly through the lower openin in the door. 8. Prior to installation, lubricate the window regulator mechanism with chassis grease. Installation of the glass and regulator is the reverse of removal.
Evan B. |
03-09-2006, 01:22 AM | #3 |
Sb 400 club
yup he has got it
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
