03-08-2006, 10:47 PM | #1 |
WTB: 305 engine in or near Iowa
Looking for a bolt and go 305 in good condition, prefer recent rebuild, but will consider rebuildable core also. Any year considered. Tell me what you may have. Thanks.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
03-08-2006, 11:17 PM | #2 |
its all about the +6 inches
Re: WTB: 305 engine in or near Iowa
305 V-6?
Or 305 small block? |
03-08-2006, 11:41 PM | #3 |
Hmm,yes, better clairify, looking for the SBC 305 kind.
03-09-2006, 12:29 AM | #4 |
72 C30 Trailer Queen
I have a 1968 307, from an 82k farmer truck.
Supposed to run pretty good, parted truck due to rust. $150 complete intake to pan, no exhaust manifolds. Add $50 for the granny 4 speed behind it. Are you looking for a 305 specifically? I have a 327 and a couple 350s, or even a 1968 396/TH400. Located just outside of Rochester, MN.
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts |
03-09-2006, 09:46 AM | #5 |
OF all the smc v8's that GM produced, 305 would not be one I would go after--but that's your call. They weren't one of the best. My first choice would be an original 71 or 72---010 block with high nickel content and 4 bolt mains. They are a much stronger block in every respect. If I had a 305 available, it would be free !!
03-09-2006, 04:59 PM | #6 |
Thats why I'm looking for a 305 becuase they are cheap or free, but If there is a nice 350 or 327 etc for a reasonable price I would bite on that also.
03-10-2006, 11:00 PM | #7 |
I think the going rate for core blocks is around a $100
03-10-2006, 11:07 PM | #8 |
YOu know I have a 305 I'm thinking about using too. I got a $80 79Malibu that has a 84camaro/firebird 305 when I ran the numbers. It didn't run. The fuel filter was clogged I had it running in 5 min. It has 150psi in all cylinders. I thought of dropping it in my 67 c10 behind the 3 speed manual. first Im changing the cam to a summit 1102, timing chain, and valve seals or valve job. I have given away 305's in the past if someone was going to use them and not resell them. I've seen a few rebuilt with a mild cam and they ran good for a truck. Maybe it could squeeze some more mileage than a 350.
03-11-2006, 06:05 PM | #9 |
ttt
