Old 03-08-2006, 10:51 PM   #1
82c10
needin' money
what do you think
what do you think of someone fiberglassing a hole in the floorboard, that don't have a welder, and they don't make a specific replacement piece for it, would it work very good to do it, need suggestions
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 03-08-2006, 10:59 PM   #2
Army_Dude
Re: what do you think
You experienced in glass? I don't really see a problem with it. Since it's in the floorboard, carpet will cover it right? How big of a hole are we talking?
Army_Dude is offline   Reply With Quote
Old 03-08-2006, 11:09 PM   #3
82c10
needin' money
no, but am going to try it, no, carpet won't at the moment, but i will be puttin, a insulation type mat down from the home depot, 12"x 3" probably
Old 03-08-2006, 11:24 PM   #4
Chevrolet4x4s
Chevrolet4x4s's Avatar
Why not rivet a patch over the hole then use the glass to seal up around it?
My $.02
Shane
1993 K1500 350 5 speed
1985 K10 Silverado Vortec 406 5 speed (in body shop)
"I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been
No, I ain't broke I'm just broken in"
1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle )
Member#20327
Chevrolet4x4s is offline   Reply With Quote
Old 03-08-2006, 11:26 PM   #5
82c10
needin' money
i don't have anything to form to rivet over it, take that back, i can't get the metal to bend like it needs to
Old 03-08-2006, 11:29 PM   #6
C-10volvo
C-10volvo's Avatar
i thought there was some sort of adheasive that you could use for bonding metal to metal.
also, i dont know how well fiberglass will bond with metal, or at all. plastic and metal shrink and expand at different rates and will crack. it really isnt that hard to fab up something and have someone weld it.
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 03-08-2006, 11:44 PM   #7
Army_Dude
C-10 Volvo makes a good point. If it's easy to get to, and not that big, I'll bet a welding shop (or just a local guy with a welder) would'nt charge that much to patch it. If it's gonna be covered, JB Weld works well on bonding metal to metal. Some people hate it, but it works. But of course, then you'd be back in the position of fabbing the patch piece.
Old 03-08-2006, 11:52 PM   #8
82c10
needin' money
i believe in JB weld, we use it at the vo-tech sometimes, it works on alot of stuff
Old 03-09-2006, 12:04 AM   #9
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
What are you trying to do? Maybe we can come up with better idea.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 03-09-2006, 01:15 PM   #10
82c10
needin' money
patch about a 12"x 3" hole in the floorboard
Old 03-09-2006, 01:26 PM   #11
Wild83C10
Wild83C10's Avatar
You can buy a piece of thin sheetmetal from Home Depot or Lowes and you can form it with your hands or a hammer. Then rivet it to the floorboard. I used the same sheetmetal to cover the 4-spd hole in my transmission hump.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 03-09-2006, 03:50 PM   #12
Slonaker
Insert Witty Text Here
Slonaker's Avatar
My dad was a big fan of repairing metal with fiberglass. I always found that odd, since he knew how to weld, and had the right equipment. Everything on the old car I inherited from him that was patched with fiberglass is falling apart. It all rusts out around the fiberglass patches.
I would try to find someone to weld it. If not, I would spend a little time forming a patch panel, rivet it into place, and seal it with seam sealer from a bodyshop supply place.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-09-2006, 06:36 PM   #13
cutter61
cutter61's Avatar
3m makes a wicked panel adhesive-once it's on it's on for good- alot of the new cars are "glued" together on the assembly line-bang the crap out of a couple pieces of sheetmetal till you get one right-kinda fun-good luck
If ya don't get at it when ya get to it,You won't get to it to get at it again.
cutter61 is offline   Reply With Quote
Old 03-09-2006, 07:21 PM   #14
82c10
needin' money
well, i though of getting a benzomatic propane torch, and heating it upto be easier to bend
Old 03-09-2006, 08:47 PM   #15
us111
i'm not even close to being a body man,,but alway's being short on money you learn a lot,,,a patch that size on the floorboard with a big hammer,piece of wood or whatever you can make something close to what you need,,maybe like mylilbowtie said,,little more info and these guy's can tell ya just about anything....
us111 is offline   Reply With Quote
Old 03-09-2006, 08:55 PM   #16
Corellian Corvette
My Dad is ALSO a fan of repairing metal with fiberglass. He too knows how to weld and does paint and bodywork when he feels like it.
The key to make sure you get rid of ALL the old rust before patching anything. If you have a 12x3 whole, make it a 12.5x3.5 hole that you're attaching to clean metal. Prep the metal with rust-proofing (POR15 or equivalent) and glass over the top. Make sure you follow-up with a good primer/sealer and a topcoat or you will rust again.
Even a welded-in patch panel will re-rust if not primered and top-coated.
Corellian Corvette is offline   Reply With Quote
Old 03-09-2006, 09:03 PM   #17
Chevrolet4x4s
Got a photo of the hole so we can give more detailed advice?
Shane
Member#20327
Old 03-10-2006, 12:57 AM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
It doesn't matter if you use a sheet metal patch or glass over the hole it will still continue to rust. You need to cut the rust out, or clean and neutralize it with a rust conditioner like Metal Mort.
Once you have done that, it's not that hard to form a patch panel and weld, pop rivet, or panel bond it in place...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
