454 exhaust gasket - what works????
My exhaust manifold gasket developed a nasty leak this fall. I finally got fed up, and rather than screw with it for an entire weekend, I sent it to my trusty mechanic, who put in a new Napa exhaust manifold gasket. Nice and quiet. For a month.
![]() A buddy of mine suggested a copper manifold gasket. They seem to work well with headers, but I've never talked to somebody that's used them with stock manifolds. Is a copper gasket going to be an improvement over a stock style, or is there something better out there? This is a 100% stock tbi 454 except that it's got dual exhaust. It still has the stock manifolds though. Thanks. |
Re: 454 exhaust gasket - what works????
If your talking about the exhaust doughnut I have a metal one on mine (smallblock).......still leaks but the pipe may be flared incorrectly as it eats normal doughnuts(exhaust ones that is) about a week for the last one.But i have heard good things about the metal doughnuts.
Shane
1993 K1500 350 5 speed ![]() 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ![]() Member#20327 |
Thanks, but I'm talking about the exhaust manifold gasket between the head and the exhaust manifold.
Slots go on anything!
I don't see why it wouldn't work.
1974 Jimmy- 5.3/4L80e/NP241 |
Make sure that your manifold is not warped. If it had been leaking for any long period of time it may have been. You may need to have it surfaced. If it's continually blowing gaskets it could be. You can take it off and place it on a flat surface gasket side down. You'll be able to see if it's warped.
-John II "A Little's Good! A Lot's Better! & Too Much is Just Right!!" -1978 Chevy C10 Stepside 350/4sp/12 bolt -1967 Nova 2dr HT & a couple others... ![]() |
OOOH You usually dont have any problems with those just put it on and torque it
#7 | |
Found a trick with the paper style exhaust gaskets, soak them in water for 12 to 24 hours then install them this causes the gasket to conform to the two surfaces has worked on a nasty set of leaky black jack headers on a 383 I raced.
No No
I only use header gaskets on BBC manifolds reguardless if they have headers or stock manifolds. After having a few very tight fit motorhomes blow stock gaskets it forced me to give up on the OEM stuff. I usually go for the Mr Gasket Ultra gaskets. They seem to hold up fine with just enough squish to seal minor imperfections. One motorhome blew 3 stock gaskets in 4 months, switched to the header gasket and it hasent leaked in 2 years.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
ureckmefixit2@cox.net
Have your manifold checked, it's not going to hold any gasket. have it re-sufaced
That's U RECK ME FIX it 2 74 Chevy Short Bed 355ci Sportsman II 64cc Angle Plug Crower Custom Grind .462in .486ex Dyno Test 422hp @ 5600 And it's got a Holley 3.73 Gears 12 Bolt 3.73 w/Posi 700R4 Going In I'm a Body Man So There! That's why it's not painted |
Thanks guys. I'll check out the manifold next time I pull it off, and I'll give the Mr. Gasket Ultras a try. I've heard so many motor home horror stories, that I somehow doubt that my problem is unique.
#12 | |
![]() Shane
#13 |
Right turn Clyde
Dont soak your gaskets in water it will only ruin them.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
