Old 03-09-2006, 11:39 PM   #1
Blot72
Transfer Case Torque Mount
OK, I bought a new NP205 for my TH400. I am very happy. Question. Has anyone used a torque rod instead of the Mount to the frame rail? The rod bolts up to the two holes on the side of the case then up to the bellhousing. I heard that it reduces alot of the vibration from the case. In order to use the rod the passenger side upper bracket of the crossmember must be eliminated. Does this sound OK. Will it weaken the member enough to worry?
Blot72 is offline   Reply With Quote
Old 03-09-2006, 11:50 PM   #2
vtblazer
vtblazer's Avatar
Re: Transfer Case Torque Mount
That wasn't available until after our trucks.
I had never hear of not needing a cross member though, when using them.
Any pics, diagrams?
vtblazer is offline   Reply With Quote
Old 03-10-2006, 08:14 AM   #3
Blazerb61
I have seen a coupleguys do this supposed to keep the adaptor from tweaking and being broken I dont have the supposrt on the side of my transfercase and more cause I keep breaking adaptors I run a 4 speed though am going to install that rod this weekend
Blazerb61 is offline   Reply With Quote
Old 03-10-2006, 09:44 AM   #4
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
Is this what you need
Gary 70 Jimmy is offline   Reply With Quote
Old 03-10-2006, 11:50 AM   #5
Burt4x4
Burt4x4's Avatar
Hey Blot72
Another thought is the vibration realy won't be noticable...I mean thease trucks aren't all that vibration free to begin with. The factory tranfer case torque mount bracket does have rubber mounts to the frame. I replace mine with a poly set instead of rubber...all my mounts are poly actually.
I can't find a pic of mine...
Burt
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 03-10-2006, 09:28 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Waiting to see where this goes, seems like good info
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-12-2006, 09:44 PM   #7
Blot72
Thanks Guys.. Yea I have the stock mount to the frame with the new poly bushings. I havn't installed my tranny and motor yet. A guy here at my local salvage yard (and very smart when it comes to chevy 4x4s) told me it might be smart to convert to the torque rod. I will get photos when I get to that point. Not quite sure when. Im just thinking ahead. I did however buy a torque rod on ebay. The guy I bought my Tcase from had one and threw it in. Cant hurt to try.
Old 03-13-2006, 11:56 AM   #8
Burt4x4
Burt4x4's Avatar
Well when you get down that road take some pics so we can see too
Have a great week
Burt
Old 03-14-2006, 10:48 AM   #9
Burt4x4
Burt4x4's Avatar
New pics:
Also a shot of how low the drivers side Thorley heder hangs down
Shot of the ORD engine mounts on a 73+ x-member
Pass side collector.
Hope this helps.
Old 03-15-2006, 08:44 PM   #10
454_72_4X4
454_72_4X4's Avatar
Burt4x4, Did you add an extra crossmember behind the transfercase? Never seen one like that.
Also got any pics of your clutch linkage?
I'm gonna have to do that 73+ front crossmember next time I have the engine out.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 03-16-2006, 11:57 AM   #11
Burt4x4
Burt4x4's Avatar
Hey 454_72_4x4
My K5 came with that 'dual' crossmember. As far as I know that is a factory option, just like the gas tank skid plate my K5 had also. It is simply two of the front crossmembers with a skid plate under the Xfer case.
Clutch linkage...whats that? hahhaaa
I converted to Hydro:
This is the slave cylider from a Toyota LandCruzer & Advance Adapter mounting bracket bolted to my bellhousing.
GM Master Cylinder from '87 truck (painted green). I made the T bracket to mount the lil resavor to.
I made a thick spacer to bring the master out a bit as the shaft was slightly too long and without the spacer the rod was slightly pushed in and I had a terriable time getting all the air out. Once I moved the master out so the rod is not pushing in at all I was able to bleed all the air out.
By the way the master cyln. is mounted upside down too. A first gen friend of mine did this first. It is upside down due to the angel of the master's mounting plate. Some have made a 'dagree shim' to level it out and mount it right side up....seams to be working great so far so I will just leave it the way it is.
Hope this helps
Burt
Old 03-16-2006, 05:55 PM   #12
454_72_4X4
454_72_4X4's Avatar
Originally Posted by Burt4x4
Hey 454_72_4x4
Hope this helps
Burt
Thanks Burt!
I'll be converting to Hydro clutch when I swap in the NV4500 trans. My can't be completely like yours because the trans I have uses a internal hydro slave cylinder.
I have a master cylinder off of a Datsun? 280z? (I think) that I'm going to try to use. Mostly because it's all aluminum and should last forever.
Now I better quit jacking Blot's thread before I get in trouble...
Sorry Blot72, but just to stay on topic, mine has the same torque mount as shown in Burt's pics. I've seen the strut you're talking about but I don't have any idea if one is better than the other.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
