Old 03-10-2006, 12:49 AM   #1
CochinoFilipino
CochinoFilipino's Avatar
Is this a 73-87 bench seat?
I want to take the Prelude bucket seats out of my 67 and put in a bench. I've been offered this seat on the 67-72 board. I want to know exactly what it is from so that eventually I can recover it.
Thanks,
'67 C10 Short Stepside 5.0TPI/700R4
CochinoFilipino is offline   Reply With Quote
Old 03-10-2006, 01:08 AM   #2
Russell
Professional Grade
Russell's Avatar
Re: Is this a 73-87 bench seat?
Looks like an 81+ bench seat to me!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-10-2006, 02:05 AM   #3
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
I'm not sure...
It may be angle of the picture, but it doesn't quite have the same profile of a '83 bench. The floor bracket peeking out from underneath the passenger side looks different as well. Got any pics of the side profile or the underside?
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 03-10-2006, 02:58 AM   #4
Russell
Professional Grade
Russell's Avatar
Originally Posted by boxrodz
I'm not sure...
Now that you mention it...
It is common for the brackets to misalign themselves when unbolted from the floor, but you're right, that doesn't look like the normal bracket does...
Old 03-10-2006, 03:49 PM   #5
CochinoFilipino
Pics posted by the seller in this thread: http://67-72chevytrucks.com/vboard/s...ght=bench+seat
He mentions that something was done to the legs.
Old 03-10-2006, 03:55 PM   #6
bigblock73
yeller
bigblock73's Avatar
That is definately a 73-87 bench, the sliders and adjustment handle look like every other one I have seen.
bigblock73 is offline   Reply With Quote
Old 03-10-2006, 04:06 PM   #7
CochinoFilipino
Cool. Thanks.
Old 03-10-2006, 08:22 PM   #8
a28doc
'87 V20 4x4
a28doc's Avatar
def a 81 to 87 bench and slider is also I know when I have ever taken a bench out and put back in it never seemed to line up again it always took some tweaking
Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
Old 03-12-2006, 11:27 AM   #9
86swb
Born a Chevy Man
86swb's Avatar
Looks like the seat in my '86.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 03-13-2006, 03:33 AM   #10
kevinr1970
You guys sure thats an '81+ seat?
I thought the brackets bent down in the front and bent up in the rear? Also, all the benchs I've dealt with (all of about 3) only had one mounting hole?
***EDIT***
Took a look at the bench in the garage and it looks totaly different than that. That one looks like its meant for a flat floor. The one I have has the slider lever on the front and that one has it on the side.
That pattern looks more like a the pattern you would see in an '88+ truck (newer body) and I think those seats mount flat?
Heres a picture of mine.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 03-13-2006, 12:17 PM   #11
1Ton
1Ton's Avatar
The bench in question looks like someone welded some different brackets on it to fit something else. Make sure you cancut those off clean. Or put new ones on.
Support your local search and rescue team.... GET LOST!
Originally Posted by DURRTY
if some is good
more is better
too much ought to be enough........
1Ton is offline   Reply With Quote
Old 03-13-2006, 03:23 PM   #12
kevinr1970
Looks like they welded some box tubing to some factory brackets. Not saying those are the original brackets for this seat though?
I guess the picture I posted doesn't really show the bends in the bracket very well. If needed I will get a better one.
And by the pattern, I meant the pattern in the fabric with the horizontal "lines" in it.
2000 Tahoe Limited
