Active Member
Hard top removal
Re: Hard top removal
How much does a top weigh? I would have to believe it's pushing that 250 lb limit.
Still, it wouldn't be too tough to make something similar out of heavier steel.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#3 | |
If it aint broke..............fix it till it is. www.fast77.com 1972 - 330 hp crate, 11" lift with 39x18 mickeys. 3/4 ton, cross steer, 4 wheel disc brakes 1996 Z71 w/ 35's |
I miss this truck.
The thing is, you could buy a lot of pulleys, cable, and winches for that same $139. I've been kicking around ideas like this for a buddy's Jimmy. A couple of 2x4's with an eye-bolt through each end to attach the cable to, then a small pulley directly above each end of each 2x4, then a larger pulley somewhere to turn all 4 cables back to the winch. You could even drill holes through the 2x4's to run your bolts through so that your top maintains its shape while its off the truck. He even found a small electric winch in harbor freight he was thinking of wiring up for this purpose.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
SKINNY TIRES RULE!
There is a lift made specifically lifting off tops. I don't know what the lift for the blazer looks like and it is fairly expensive.
http://www.truckstuffusa.com/hoistatop.html
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Back in the sticks
BobbK made an outfit to remove his and put it on the board. I don't think its in the FAQ, but if he sees this maybe he'll post a link. It looked like the way to go. Pulleys, hoist, all the goodies and it put his top way up in the rafters of his garage.
I don't think the double wall tops are that heavy though. I have moved mine around by myself. I usually just stand up under it and walk around with it. Course it takes the wife to help me get it off the Blazer like that too. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
![]() Join Date: Apr 2004
anyone know what the top weighs?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
SKINNY TIRES RULE!
With a hatch, I'd guess in the 200-250 lb range. The biggest problem is they are awkward and easy to damage.
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Mike
Here is the one bobbyk did
http://public.fotki.com/blazbk/blaze...eing_the_roof/
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
#11 | |
It's ok to stare...
#12 | |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
The forum pic's have captions,the Fotki site doesn't,but it does have ALL the pic's I took(both the 1st and 2nd design). http://67-72chevytrucks.com/vboard/s...d.php?t=159221
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
#13 |
No,I DON'T have Tourett's
I'm pretty sure the roof trusses in my garage wouldn't enjoy the load.
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
#14 |
![]() Join Date: Feb 2004
I would think that it would be pushing the pounds limit too...
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
#15 |
Don't tell me a 2X6 or even a 2x4 roof truss can't support 300lb's.
Take your average man at 180-200lbs,throw 2 guys up on a roof,one standing on each 2x6 truss....is the roof going to colapse...I don't think so. If it did,I'd find the guy who built your roof and punch him in the head. A winter's snow load is much heaviear that a few hundred pounds. In short...your trussess can carry that load without a problem(sorry for being so long winded)
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 03-13-2006 at 08:24 PM. |
#16 |
Now maybe the trusses are designed differently in different parts of the country, but here the trusses are designed for 2 things only. Support the roof and support the weight of the sheetrock on the ceiling. No attic storage ability. Now of course there are variables everywhere. We put the AC/heater in the attic and the trusses there are designed to support them. There are girder trusses designed to carry more loads, etc. Sheetrock alone is pretty heavy. So Yes, the trusses probably will hold up, but be careful especially if you have a new home in warranty. The snow load (which we don't have
![]() ![]() In short, I've done it too, in a garage where there was no sheetrock, and yes it was fine, just be careful. Last edited by k-nuts; 03-13-2006 at 11:06 PM. |
#17 |
Typical roof trusses are designed to support a load from the top. The bottom chord of a truss is designed for that purpose ( actually it is in tension), not as a load bearing component. I am very careful not to overload the bottom chord.
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater Last edited by blazerparts; 03-14-2006 at 11:01 AM. |
#18 | |
Premium Level Member
69 K5 CST stock- 350, 4speed ![]() 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, |
#19 |
HEY jakeslim, i havent seen you around in a while, maybe its just me?
#20 |
Has anyone tried Caplift? They say it is rated up to 240 pounds. I am also looking for a way to get my Hardtop on and off easily and out of the way when it is not on the truck.
#21 |
wow, a 5 Y/o thread back from the dead. I haven't used the Caplift, but I do take my top on and off by myself. Although I've only put it back on twice in the last few years it pretty easy. I built a frame to slide under the top, then I used heavy duty ratchet straps to ratchet the top out of the way. It's high enough I don't bump my head.
#22 |
Ya... this one is old for sure.
The latest incarnation of my lift is posted here. No 2x2's in this version. http://67-72chevytrucks.com/vboard/s...d.php?t=398105 I have pic's of the top on a scale so we finally know the weight of a single walled top. It has a link to a short video of it going up as well. .
