Old 03-10-2006, 03:23 AM   #1
Russell
Professional Grade
Russell's Avatar
Power Window Wiring Question
Hey guys!
My truck has power windows, but I've run into a bit of a problem here. I replaced the window / lock harness, cause the old one had been hacked into many times in the past, and simply was beyond saving. However, I went to plug everything in, and of course, the very last connector is different, DOH
The power lock component of the harness is the same, and works just fine, as is the driver's side of the power window harness. However the difference is in the passenger side power window harness connector. The original harness had a 4 pin connector, with a pink 12 volt wire, black ground wire, blue wire and a brown wire. The new harness has the 12 volt wire, ground wire, and only the brown wire, while the driver's side has all four.
What gives? Driver's side only able to put the pass side window up / down, and not the other way?
Anyone have any ideas, such as where that blue wire went? lol
Presumably, the blue wire and brown wire from the driver's side to the pass side are for the driver's side to control the pass side window, while the pink and black wire provide power for the window.
In the stock harness, the blue wire goes from one connector straight over to the other.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
