03-10-2006, 09:47 AM | #1 |
20" rims on 79 chevy BS questions
Hey guys, I am getting ready to order a set of rims for the 79. Its gonna be bagged w/ 1.5" c-member drop. I want a set of 20" Panther Juice 5's. I plan on running a 40 series tire.
Just wondering what specs you guys used when getting ur rims/tires without rubbing anything. I already know I cant use inner fenderwells, and i have to cut my rear wheelwells out. anything else ill need to get rid of in order to run 20's front and back? |
03-10-2006, 09:48 AM | #2 |
Re: 20" rims on 79 chevy BS questions
03-10-2006, 12:57 PM | #3 |
Ken is running 20's and his truck isn't cut at all. Ken, Ken can you help this man please?
See if this link helps you at all. http://www.imagestation.com/album/?id=4290400437
1959 GMC project Last edited by Jebb1978; 03-10-2006 at 01:00 PM. |
03-10-2006, 07:47 PM | #4 |
ttt
03-10-2006, 08:20 PM | #5 |
It all depends on what you're attempting to do.
Kens truck has 20x8's up front w/5.25bs & 245/40's. The lower arms are trimmed to prevent unwanted scraping & he has the stock size inner fenderwells. On the back, he has 20x9.5's w/either 4.5 or 5" bs (I can't remember 100% which one it was) & 295/40's. The rears required no mods to fit. These sizes fit w/o issue because Ken isn't trying to plant his framerails. They work for the way the truck is designed. If your plan is to plant the rails, a different bs will possibly be required.
03-10-2006, 10:05 PM | #6 |
Yea, I am definetly planning on planting the framerails on the ground.
03-10-2006, 11:23 PM | #7 | |
I would say you'll need more back spacing & mini-tubs on the rears unless you cut out the inner wall of the bedside for clearance. One suggestion.... keep a close eye that you don't get overly aggressive on the rear bs & wind up w/the front track width visibly wider than the rear (a major no-no in the custom/slammed truck scene IMO).
03-12-2006, 10:13 PM | #8 |
Im still stuck on the backspacing, its kinda hard to do with a bare frame, and none of the suspension bolted up :P
03-12-2006, 10:45 PM | #9 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-12-2006 at 10:46 PM. |
03-12-2006, 10:51 PM | #10 |
ya my dad keeps tellin me we need the rims to set the suspension up tho :P I guess ride height and all.
03-13-2006, 02:19 PM | #11 | |
Happy to be here
I suggest this because it doesn't sound like this project will be done in the next few months. By then you may look at those wheels and have a different opinion of how they look.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 03-13-2006 at 02:19 PM. |
