Old 03-11-2006, 07:47 AM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Complete 5 lug front suspension and brakes in DFW
This is a 75 model disc brake crossmember, steering, and suspension. I'm posting it here because it's good for a disc brake update on the earlier drum brake trucks. If you're doing a crossmember swap to get rid of your drum brakes, this is what you need.
I have everything from the master cylinder to the wheels. All brake lines are there and intact. The tires a blown, but wheels are there.
Complete hub to hub. I'll cut the whole frame off and give you the front half of the truck if you wish minus the steering box. This is the stuff most guys use when doing a crossmember swap. Like has been posted here many times, it's a bolt in with slight egging of two of the holes.
Swaybar not included. It's already spoken for.
125 dollars, no shipping. DFW area.
Old 03-12-2006, 01:54 AM   #2
GlennBrittain
Re: Complete 5 lug front suspension and brakes in DFW
I need one, the price is right where are you located. Mesquite is a 3 hour drive, longer pulling a trailer.
GlennBrittain is offline   Reply With Quote
Old 03-12-2006, 07:00 AM   #3
Tx Firefighter
I can brint it to my work in Hurst.
Old 03-14-2006, 12:02 AM   #4
GlennBrittain
After checking the atlas for Pooville, Hurst sounds good. I can not make the trip untill next week. I am just now getting my roofs replaced from the storm. I already have commitments for the latter part of this week. If you find a buyer before then sell it, I could not blame you in any way for selling to the first with cash in hand. If you dont, do you have a way to lift it inorder to load in the back of a Ford Ranger or do I need to bring a low boy. Directions, contact number and a good day also.
Old 03-14-2006, 07:13 AM   #5
Tx Firefighter
Glenn, I looked close at this one, and both of the lower control arms are bent a good bit. I'm glad I saw that before selling it.
If you still want one of these, I should have another truck soon that will have another front end on it. I've got a couple of trucks that I'm supposed to buy to part out. I'll post it when I get the trucks.
Old 03-14-2006, 05:55 PM   #6
Primered_69
Primered_69's Avatar
Would you be interested in selling the front brake lines? If so shoot me a PM
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 03-20-2006, 11:27 PM   #7
GlennBrittain
If I have not found one by then, I will still be interested. I am taking my PC down in the morning for a overhaul, if I have problems it may be awhile before I am back on line.
