03-11-2006, 06:31 PM | #1 |
Rolled on Paint Club
Removing undercoating?
I finally got my cab off of the frame today. Not easy to do alone with only a bottle jack and some scrap lumber. Now that I have the cab on its back I see that several of the PO's had coated the underside with every imaginable goop to prevent rust. Also found some seam sealer holding on cab supports and white kitchen and bath caulk sealing the back of the rockers.
Is there any trick to removing the tar-like stuff? Some is still pliable, and some is very textured and hard as a rock. Bob |
03-11-2006, 06:57 PM | #2 |
Re: Removing undercoating?
auto paint supplier and ask for undercoating remover/// or eastwood will sell you "underoff" for twice the price as locally
03-11-2006, 07:44 PM | #3 |
Psycho-billy Member
I use Ditzler DX-330.
'72 C-10 350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers. Support your community, support yourself. Buy local, buy American (or Canadian). |
03-11-2006, 08:05 PM | #4 |
I tried mineral spirits, but the real trick is Kerosene !!! Yep, works like a charm, Diesel fuel should work too, put it on, keep it wet for a while and it will come right off. If you have a pressure washer that would be even better.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
03-11-2006, 08:25 PM | #5 |
Thanks for all the ideas guys. I'll start soaking it tomorrow!
Bob |
03-11-2006, 11:32 PM | #6 |
horsepower junkie
i used a propane torch...heat the area then scrape.....works okay ....gets a little stinky at times...
67 short wide box,350/700r4/3.73posi 71 olds cutlass "S" mom bought new..12.30s@113MPH |
