Old 03-12-2006, 12:05 AM   #1
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Easy Winshield Washer
My truck, like alot of others had serious issues with getting enough water on the glass to do the job. Here is how I fixed it.
Obtain a Dodge Ram like this.
Chisel out the mounting bracket. It has 2 spot welds. They come apart easy.
The mounting bracket spot welds get gound smooth and the bracket gets painted.
Push the hose from the washer bottle 3 - 4 inches up your original hose. Cut Your supply hoses and install a vacuum tee.
Pull the connector from your washer motor and use spade connectors to hook it up to your new washer.
Works great.
low'n slow is offline   Reply With Quote
Old 03-12-2006, 12:12 AM   #2
low'n slow
low'n slow's Avatar
Re: Easy Winshield Washer
Vacumm tee. Sorry no pictures under the dash for the wiring.
Old 03-12-2006, 02:09 AM   #3
ACES
Life is a gamble
ACES's Avatar
Thats cool, Thanks. I'm gonna head to the Junkyard on Monday to look for something similar.
1970 Orange CST C-10 w/350, posi, Longbed
The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine.
-- Ralph Waldo Emerson
ACES is offline   Reply With Quote
Old 03-12-2006, 12:38 PM   #4
Andy4639
Old member
Andy4639's Avatar
I got a small car jug with electruc motor and the arm sprayers and hooked up. I placed the sprayers in boiling hot water and vise gripped them on the arms to stay until they cooled off.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
