Old 03-12-2006, 09:34 PM   #1
76bonanza
76bonanza's Avatar
idle mixture
When adjusting the idle mixture screws is it best to take the vaccum reading from carb or intake? Just wondering if it matters.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 03-12-2006, 10:40 PM   #2
clay68c10
clay68c10's Avatar
Re: idle mixture
Whatever gives you full manifold vacuum. I think it's easiest to go off the brake booster line. Some of the carb lines may be ported vacuum for timing advance, EGR or whatever.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 03-12-2006, 10:58 PM   #3
76bonanza
76bonanza's Avatar
Re: idle mixture
ya I normal use the full vaccum off the carb but just wondering if it would be better off the rear intake port.
1968 c10
lowered 3" 4"
Old 03-12-2006, 11:51 PM   #4
Karl Hoh
A little east of nowhere
Re: idle mixture
The rear intake port or anywhere on the manifold below the throttle blades will give you a true vacuum reading.
Karl Hoh is offline   Reply With Quote
Old 03-12-2006, 11:54 PM   #5
qksilver
Re: idle mixture
Make sure your timing is set right and points dwell too, before you try to adjust the idle mixture. You will have to reset the idle speed.
You can also set the idle mixture by going for the highest idle speed when turning the screws
qksilver is offline   Reply With Quote
Old 03-13-2006, 12:02 AM   #6
76bonanza
76bonanza's Avatar
Re: idle mixture
No points qksilver HEI. I find it is easier to set with a vaccum gauge. I think I will just pull the hose going to the tranny on the manifold and hook up there.
1968 c10
lowered 3" 4"
Old 03-13-2006, 01:35 AM   #7
MDC
MDC's Avatar
Re: idle mixture
That should be good. Anything below the butterflies should give you full manifold vaccuum.
67 C10 Shortbed 327
05 F150 4x4 NO APPOLOGIES 's
02 Xpress X19 02 Yamaha VMax 150
www.xpressboats.com
Nothing says 'poor craftmanship' like wrinkles in your duct tape
MDC is offline   Reply With Quote
