My Beater: What Color for the 350
I'm getting closer to completing my 6/3spd to 350/350 swap. What do you guys think for engine color: Basic black or a splash of color?
Re: My Beater: What Color for the 350
Beater truck huh? Better go black.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
4 eyed fever
chevy orange! Otherwise my 4 YO girl wouldn't know "it's a small block chevy".
1971 GMC 2500 4x4 1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto. 4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!! |
Basic black...no matter what the truck.
I think the world needs a drink... ![]() Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd ![]() Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
#5 | |
Gone Fishing
I would only go Chevy Orange just my opinion
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
Black
67 C10 Shortbed 327 05 F150 4x4 NO APPOLOGIES ![]() 02 Xpress X19 02 Yamaha VMax 150 www.xpressboats.com Nothing says 'poor craftmanship' like wrinkles in your duct tape |
Hmmmm... I like the look of black but often wind up working on my cars in less than ideal lighting conditions so I prefer something lighter. I am going through this same decision process right now for my '93 suburban. In your case I'd say go for a splash of color.
2004 Kawasaki KLR Always looking for a cheap driver |
Color
"You can take the man out of PA, but you can't take PA out of the man" |
collector of vintage rust
o.k.......I suggest gm blue..Just to be different! lol
I personally bleed chevy orange !!!! |
orange is the only way to in a classic. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
~Rest In Peace~
lime green
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
#13 |
I'd say stay away from the fluroescent colors and bright ones. Those colors look like S**T once they're dirty on a work truck. To be different I did my last motor in the that cummins tan color. with black valve covers. I liked it and would use it again.
#14 |
Black
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#15 |
There's a lot of loyal black & Chevy-orange guys. I wasn't thinking black but after coating some parts w/the POR15, I'm reconsidering.
The truck is the med.-bronze color w/black bumpers, door panels, mirrors, & gauge cluster. The black would fit well but I know it's harder to determine the origin of leaks on a dark colored motor (that may be a good thing ![]()
#16 |
![]() Join Date: Feb 2004
I put in a crate motor that was chevy black, wish that I hadn't painted it the chevy orange, Don't quite know why just would prefer the black
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
#17 |
How much can you actually see anyways ?
#18 |
I say go with chevy orange.
#19 |
if i was using a chevy engine it would be orange without a doubt but since i'm not because i don't have a big block i'll be using dark jade green metalic to match the body on my pontiac 400
common sense isn't so common anymore |
#20 |
laying low
![]() Join Date: Mar 2001
Well...if it's just a beater it don't make all that much difference then does it? Gonna have any aluminum or chrome on it? GM engine blue looks good and will stand out from the dark inner fenders and core support but not be flashy. Or how about a Pontiac engine blue from the 70's? Or Olds engine gold. That might go well with the exterior color.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#21 |
Aluminum slot wheels rule...
Chevy orange. It IS the forth best color after Red, White, and Blue!!
![]() Last edited by JAKES 68GMC; 03-13-2006 at 09:27 PM. |
#22 |
Med Bronze like the exterior of the truck would look nice, but then it won't be a beater for long, as you may find yourself "tricking out" the rest of the truck.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
#23 |
Happy to be here
![]() Join Date: Mar 2000
Medium tan, and paint the rallies to match...
#24 | ||
![]() Quote:
#25 |
Born To Lose Club
![]() Join Date: Feb 2003
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Once you go black you never go back...or so I've heard
Brian Smith ![]() 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
