Old 03-13-2006, 04:21 AM   #1
kevinr1970
Difference - LWB and SWB fuel tanks?
Are they the same or different? If different, could I use SWB tanks in place of LWB tanks?
Reason for asking is I have an '86 GMC 4x4. I replaced the engine with a rebuilt engine with a hot cam and although I have finally gotten it to run right, the mileage is extremely poor and judging by the smell of the exhaust at idle its never going to pass smog test.
I have a 2wd Blazer project with no emission concerns that could use this engine. I have an '87 parts truck with TBI 305 that I would love to put in the GMC as I drive it fairly often and could use the better mileage.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 03-13-2006, 11:45 AM   #2
74Chevy74
Re: Difference - LWB and SWB fuel tanks?
They are different, LB came with a 25 gallon tank, and SB came with a 16, in rare cases some LB's had 16's. I have a LB that I shortened to make a SB and I had to put a 16 gal tank in it, the tank has two straps that hold it in each with 4 bolts, the front lines up but the back only 2 bolts line up, so you have to redrill 2 holes, it's real easy if you can take the strap of the tank and use that as your reference as your under the truck, much easier than holding a huge tank up. Hope this helps!
74Chevy74 is offline   Reply With Quote
Old 03-13-2006, 12:17 PM   #3
bigblock73
yeller
bigblock73's Avatar
Long boxes usually came with 20 gallon tanks...short beds all had 16 gallon tanks.
bigblock73 is offline   Reply With Quote
Old 03-13-2006, 12:26 PM   #4
74Chevy74
OOOPs! yeah that's what I meant! Sorry about that. I was thinking 25 cause that what some blazer/suburban's are.
Old 03-13-2006, 03:19 PM   #5
kevinr1970
My GMC must be one of the rare ones? It only takes about $25-$30 to fill one tank. Don't really pay attention to the gallons, but gas is about $2.29 right now.
So, if my truck has 16 gal tanks now the tanks from the SWB should bolt right up? I tried to look at a few parts suppliers and they didn't have any notes for SB vs. LB so it looks like they are the same.
2000 Tahoe Limited
Old 03-14-2006, 12:36 AM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
If you want Short tanks in your LWB truck, they will bolt in just like a SWB truck. They just won't fill up the space like the long tanks would.
piecesparts is offline   Reply With Quote
Old 03-14-2006, 01:17 AM   #7
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Unless the long bed came with dual tanks then it got a pair of 16 gallons...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 03-14-2006, 03:12 AM   #8
Russell
Professional Grade
Russell's Avatar
The 16 gallon tanks are both nice, and not, lol
It only costs 45 bucks to fill, once a week, but a guy can only go like 300 - 320 miles on a tank (highway driving), even less city driving... Feels like you've gotta stop at every gas station, and its a bit stressful if your gauge gauge wire came undone (with a stepper, there is no way to reach under and put the wire back onto the sending unit without pulling the bed)
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-14-2006, 10:24 AM   #9
swb85
On a budget like Fred Sanford
swb85's Avatar
I think if they were going to use 16 gallon tanks they should have at least put two in the swb. I only have one 16 gal and I have yet to get more than 175 miles to a tank. I have a real hard time driving by gas stations.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 03-14-2006, 11:09 AM   #10
86 GMG
my 86 swb has 16's and my 84lwb has 16's also but a 77 lwb partsd truck i had had 20's but it appeared that the p.o. installed the second tank my god the are huge to wrestle out by yourself and half full this is just my experiences and not known to be accurate to what they installed factory but we all know how gm thru things together sometimes with what they had laying around
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 03-14-2006, 01:26 PM   #11
Russell
Professional Grade
Russell's Avatar
Overdrive and a light foot help that problem, lol
Old 03-14-2006, 02:02 PM   #12
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I know the feeling. Try having two 20 gal. tanks both have to be filled with 92 octane or better (nothing less will work in engine) and no OD tranny with 3.73. Wors great in town but when you hit the loud pedal the speedo moves as fast as the fuel gauge.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 03-14-2006, 03:30 PM   #13
swb85
swb85's Avatar
I feel the pain man, I've got no overdrive and 3.42's. Get a whopping 12mpg if I keep my foot out of it and shift under 2k rpms. At least you have 40gals to get you more than 3 days between fillups. I really need a second gas tank. Sure glad I can run on the "cheap" stuff though!!
No kidding......one day I WILL have a t56 to replace the m22!!
