Old 03-13-2006, 02:29 PM   #1
70c10
67-72 Addict!
70c10's Avatar
Stereo tweeters- a few questions
I have a basic 4 speaker CD player setup in my truck and want to add tweeters. Do I just splice the wires with the front 2 speakers??. Also, does it matter where they are mounted as long as they point to me and a passenger?. I wanted to mount one below my ignition and one below my cigarette lighter and point them upward and angled. Thanks for any advice!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-13-2006, 02:36 PM   #2
farside847
farside847's Avatar
Re: Stereo tweeters- a few questions
Idealy you would want to use a crossover to separate the high tones from the mids from the lows. Then wire the highs to go to the tweeters, the mids to a mid-bass, and the lows to a subwoofer. Just splicing them in will send lows to the tweeter.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 03-13-2006, 03:14 PM   #3
70c10
67-72 Addict!
70c10's Avatar
So I should buy tweeters with built in cross-overs already in them???
Jim
Old 03-13-2006, 03:22 PM   #4
farside847
farside847's Avatar
That would be a good idea, or PM Shifty, he is very knowlegable on this stuff. (hope you dont mind Shifty...)
Old 03-13-2006, 03:23 PM   #5
shifty
Questionable
shifty's Avatar
If you can get them, that would be a good idea. Highs (treble) is directional - that is to say it will reflect off of anything. For best sound staging, you want the tweeter to be mounted in a place that will either point at the head of the listener or reflect off of something directly at the head of the listener.
I would run the tweeters off the front channel and the other two speakers off the rear I guess. These days, with amplifiers being so cheap ($80 will get you a nice one) it's hard for me to imagine life without an amplifier. Car stereos just are not even close to being made well enough to power speakers in the first place.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-13-2006, 03:51 PM   #6
70c10
67-72 Addict!
70c10's Avatar
Thanks guys. I appreciate your help.
Jim
Old 03-13-2006, 04:01 PM   #7
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
You should run the tweeters in the factory holes for the shoulder seat belts... it is definitely loud.... and you can hear it excellent... no holes required. just a thought. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 03-13-2006, 04:16 PM   #8
70c10
67-72 Addict!
70c10's Avatar
Good idea. Got any pics?
Jim
Old 03-13-2006, 05:25 PM   #9
shifty
Questionable
shifty's Avatar
the only downside to that is you'd be firing into the back of the head of the listener. I would mount mine one of three places:
In the door pillar (if possible)
In/around/near the defroster vents OR in the center of the dash in the stock 4x6 plate location.
In kick panels at your feet (cross-firing..passenger side fires at driver, driver side fires at passenger). There are some really killer looking kickpanels I've seen at this forum. I have attached some I saved for personal reference.
See, you want them to fire at the head of the person for the high range speakers, but you want to have some distance from their head to give a feeling of "distanct" which is also known as "sound stage" (I think) - emulating the feeling of space. If you got it firing into the back of your ear, the cage of the ear isn't catching it really...and it is going to overpower everything having a tweeter scream in your ear.
Old 12-01-2006, 12:54 PM   #10
shifty
Questionable
shifty's Avatar
*bump* for Boise69
