Old 03-13-2006, 05:07 PM   #1
cwilkie
Chance
cwilkie's Avatar
Rear Disk Brake Kits
Who has the best rear disk brake kits? I am looking for the best overall value. I can see a light at the end of the tunnel because my truck project is going to be mostly downhill now. I am doing an information search for rear disk brakes now. Any input or opinions is more than welcome.
Chance
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 03-13-2006, 05:16 PM   #2
shifty
Questionable
shifty's Avatar
Re: Rear Disk Brake Kits
I keep seeing the Brothers kits, the ECE kits (early classic enterprises) and Classic Performance Parts kits. I hear CPP has a bad reputation though...heard a lot of people here unhappy with them for various reasons.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-13-2006, 06:05 PM   #3
cwilkie
Chance
cwilkie's Avatar
The reason I am asking is because Athey's Classic Truck Parts has a rear disk brake kits that has everything you need to convert a truck to rear disk brakes. It comes with the brakets, calipers, rotors, mounting hardware, and even the parking brake kit. So far this is the best deal I have found for $599.95 + shipping.
Chance
BB 396 w/TH400
BB 496 w/TH400
Old 03-13-2006, 06:18 PM   #4
Frizzle Fry
Frizzle Fry's Avatar
It'd be nice if a company offered just the brackets and maybe propo-valve along with a list of parts sources. So we could buy this "install kit" and go to a junk-yard or eBay etc. to get the rotors and calipers. Something like that should be less than $200.
Frizzle Fry is offline   Reply With Quote
Old 03-13-2006, 06:32 PM   #5
Musclerodz
There is several people that offer brackets on ebay. The problem I have been having is finding a 6 lug set up. Over the weekend I found a source for new GM rear 6 lug rotors and loaded calipers dirt cheap off 2000 or newer suburban/tahoe/trucks. Should have the stuff here end of the week. I will post pics once I get the stuff installed.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 03-13-2006, 07:35 PM   #6
blazerboy72
I havent used the CPP kit but have ordered other products from them and would strongly suggest you go somewhere else. The have awful customer support and are very slow at shipping the product(took 3 weeks to get a gas tank that was in stock)
blazerboy72 is offline   Reply With Quote
Old 03-13-2006, 07:42 PM   #7
wibilly
wibilly's Avatar
use 4wd front roters at least thats what you do with eatons and 14 bolt rears
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 03-13-2006, 07:49 PM   #8
ratrod67
ratrod67's Avatar
I have the CPP kit in my truck. No problems so far...
ratrod67 is offline   Reply With Quote
Old 03-13-2006, 07:53 PM   #9
dennislbrooks
dennislbrooks's Avatar
I think Mike Hill sells just the brackets for 4 and 2 wd. He is on this forum - not sure if he is a supporting member. Here is some info.
http://67-72chevytrucks.com/vboard/s...d.php?t=178840
dennislbrooks is offline   Reply With Quote
Old 03-13-2006, 07:54 PM   #10
Vince M
Vince M's Avatar
I bought a kit from Blackbirds Custom. The kit uses 78 Eldorado rotors and calipers.
If I was to do it all over I think I would look at late model Caprices..94,95 etc. They have a 5 on 5 bolt pattern and I'm pretty sure the brakets etc would fit on a 12 bolt rear.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 03-13-2006, 09:48 PM   #11
rodnok1
rodnok1's Avatar
I used a 6 lug kit from GMCPAULS, it was easy to install overall. Follow directions exactly. I had more problems with m/c and pedal throw than anything. I welded the hose holders to axle(clamps don't look good). I've had in on 1-1/2 years now and no problems. Here's a link to my rear discs: http://home.earthlink.net/~rodnok1/c...reardiscs.html
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 03-13-2006, 10:32 PM   #12
chevybill
chevybill's Avatar
I ordered front and rear disc kits from Classic Performance Products with little to no problems. Javier is the best guy to talk to for technical support. The only problem I had with them was there were no mounting bolts for the rear disc brackets when I got my kit. I called to tell them and they would have sent me the bolts, but I already had bought them by then locally.
They recently moved so I hope that their customer service improves.
Bill Athey is a great guy to do business with and I have started buying as much from his as I possbily can since he is a board sponsor and vendor.
Bill can get you just about anything you need, just call him and let him know.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 03-13-2006, 10:37 PM   #13
hilljob26
hilljob26's Avatar
my kit is definitly for the do-it-yourselfer.if you can use hand tools,you can build my kit for about 200,calipers,rptors,and brake lines are about 120 bucks,and then you just make the brackets yourself,or have a machine shop make them for yuou using my dimensions,here is a pic of mine
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 03-13-2006, 10:50 PM   #14
shifty
Questionable
shifty's Avatar
Mike
You'll make me a super happy guy if you follow through with this Thanks for thinking about everyone else here who's interested!
Old 03-13-2006, 10:52 PM   #15
mkundo
I was thinking about making a purchase from Classic Performance Products, after speaking with Javier (very helpful) But if there is a problem with getting your shippment and parts missing maybe it's a bad Idea?
Dan
mkundo is offline   Reply With Quote
Old 03-13-2006, 11:04 PM   #16
shifty
Questionable
shifty's Avatar
Check the "reviews" forum - search each page for "CPP" or "classic" and you can read the several reviews. If I remember correctly, "missing parts" from orders was one of the largest complaints.
Old 03-14-2006, 07:55 PM   #17
Curbstone Mech
Active Member
Chance
I got a complete kit from Master Power Brakes.
I will give you two words of input- look elsewhere
Curbie
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
Old 03-14-2006, 10:46 PM   #18
fordf350
www.tsmmfg.com he will sell as many or as few parts as you like local guy that ads in all off road magazines
72 chevy k10 4sp ps pw pl tilt ac 4"lift
67 chevy c-10 ps pb 4sp
68 chevy k10 swb ps pb ac tilt 4sp
fordf350 is offline   Reply With Quote
