Old 03-14-2006, 12:06 AM   #1
74Chevy74
Factory Tach VS. Aftermarket Tach
I installed a factory tach dash I bought, and I also left the aftermarket "autogauge" I had installed to compare the two, it seems that the stock one reads about 200 RPM's higher, and react's a bit slower than the other one, is this cause it's stock?
I read all the post's about stock tach's and how to test them, it mentioned if they were slow or stuck that they were going bad, but I just think it's slow compared to the autogauge.
Can anyone tell me what they think? Do I have a bad tach or is it just Stock VS. Aftermarket.....
74Chevy74 is offline   Reply With Quote
Old 03-14-2006, 12:11 AM   #2
71swb4x4
71swb4x4's Avatar
Re: Factory Tach VS. Aftermarket Tach
It has a lot to do with the "autogauge" being a few years old and the stock gauge being 30+ years old.
I don't think you have a bad tach. I know the 67-72's are adjustable, maybe the 73+ ones are too? The 67-72 tach's have a hole in the back with a adjuster screw inside. Maybe someone can tell you if the 73+ ones do too.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-14-2006, 09:49 AM   #3
Nolowrider
Nolowrider's Avatar
My factory tach did the samething. I just attributed it to the factory setup being the old style points dizzy and I now have HEI. I removed the factory and went back to the aftermarket.
Nolowrider is offline   Reply With Quote
