Old 03-14-2006, 04:20 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
How to install or remove the funny looking fasteners?
How do you remove and install the "S" shaped clips that are used for the trim pieces like tail light bezels and tailgate trim and other molding pieces on our trucks? How do you attach the trim pieces to the clips?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 03-14-2006, 06:56 PM   #2
shifty
Questionable
shifty's Avatar
Re: How to install or remove the funny looking fasteners?
ttt
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-15-2006, 04:41 PM   #3
johnnyp
Keepin' It Stock
johnnyp's Avatar
Hard to explain - easy to do. Just twist the clip so it's wedged under the lips of the bezel/trim. The little springy thing keeps it from twisting back out. Then just slide the clip where it will line up with the hole and push it in (or if it has a screw stud, install the nut on the back.
Just play around with it, until it looks right.
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
johnnyp is offline   Reply With Quote
