03-15-2006, 03:53 AM | #1 |
OutOfMyMind & I'llNeverKnowWhy
Brand or part number for 2wd HD springs for lift?
Does anyone have a brand or p/n for the HD springs that will lift the front of a 2wd C-10 to lift the front end? Checkers carries Part No. FCS6454S, McQuay-Norris Front Coil Springs;Heavy Duty, $80 each. Are these the springs I need? Is McQuay Norris a good brand to get or should I try to find them from say Moog?
Also, I came across Rancho 1.5" lift springs, # RS6500. Has anybody used these? Summit sells for $157 for the pair. Are they any better then the HD springs? I would like the truck to be level, so 1.5" may not be enough compared to the 3" or so I hear the HD springs give. Thanks!
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! |
03-15-2006, 12:00 PM | #2 |
www.73-87chevytrucks.com
Re: Brand or part number for 2wd HD springs for lift?
Put factory replacement 3/4T springs in there. It should raise it up to be level.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
03-15-2006, 03:17 PM | #3 |
Insert Witty Text Here
Moog 6454 was the part number for the HD spings I used to have on my truck. It sat level with them on the front. I looked at 2 brands and they both had that number, so I am pretty sure that those are the ones you want.
I was planing to lower it, and was unhappy to find out I had been sold HD spriings. This is what it looked like with them installed. The fronttires are 255/70/15. Slonaker |
03-15-2006, 06:45 PM | #4 |
Justin, they should level out pretty nice, that is what i have on mine. If it looks like its not level remember the front fender openings are cut higher than the rears, so it looks like the front is higher.. check out Slonakers pic.. the front fenders are closer to the body line...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
03-15-2006, 11:52 PM | #5 |
Thanks everyone!
03-16-2006, 02:49 AM | #6 |
I'm back with 2nd truck!
I bought mine for a 3/4 ton front springs from Advance Auto Parts for $96. It ended up raising mine 3" along with the front end rebuild.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
03-16-2006, 11:32 PM | #7 |
Thanks. I'd like to rebuilt the front end too but I doubt I'll be able to afford even the ball joints
03-24-2006, 12:10 AM | #8 |
Well I had to order the springs and they'll call me when they come in. I'll post some before and after pics once I get them installed.
03-24-2006, 12:12 AM | #9 |
Don't forget to take measurements as well. This will show you how bad yours might have been like mine were.
03-24-2006, 12:12 AM | #10 |
good deal, post is you have any questions reguarding the un-install/install process..
03-24-2006, 03:11 AM | #11 |
Right turn Clyde
Measure from the bottom lip of the fender in the center to the center of the dust cap on the rotor to get a good measurement.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
04-10-2006, 12:47 AM | #12 |
The results:
Before had 1 full tank & 1 empty After had 1 empty & 1 almost empty tank Tires were same pressure, Dueler 255/70R15 with new bilstein shocks. Heights in inches using tape measure to nearest 1/16" inch. Before // after // location 15.125 // 16.75 // ground to bottom of front bumper 30.9375 // 32.25 // ground to top center of front wheel well 18.0 // 19.25 // center of wheel to top center of front wheel well 32.8125 // 32.875 // ground to top center of rear wheel well 18.875 // 18.375 // ground to bottom of rear bumper So I gained about 1.25".
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! Last edited by Justins76; 04-10-2006 at 12:50 AM. |
04-10-2006, 10:06 AM | #13 |
Does it look like how you wanted? level it out enough?
04-10-2006, 09:40 PM | #14 | |
04-11-2006, 12:27 AM | #15 |
Here's what it looks like at the control arms. Top is before, bottom is after.
04-11-2006, 02:39 PM | #16 |
definate improvement.. if you dont mind me asking.. where are you? Those pics look alot like northern new mexico...
04-13-2006, 01:56 AM | #17 | |
04-13-2006, 09:05 AM | #18 |
wasnt too far off..
