Old 03-16-2006, 01:08 AM   #1
davidh
davidh's Avatar
71 leaf spring frame swap on my 67.
I think I"m going to put my 67 over on this 71 frame. It has leaf springs. I was going to put psteering, discs, so forth on my 67 but I thought if I have to pull the front clip to heat up and dimple the frame for power steering, do the front end conversion, find V8 mounts, 5 lug rear this would be way easier. The guy I know will trade me frames straight across so he can make a pickup bed trailer out of it. http://67-72chevytrucks.com/vboard/s...d.php?t=181551 (the cab is going on his 4wd GMC.) I might be able to get the steering column. I'm going to do this full swap, rebuild the topend of a 305, turbo 350 auto in May and try to have it ready for our old car cruise on June 2.
Any comments or suggestions?
davidh is offline   Reply With Quote
Old 03-16-2006, 01:12 AM   #2
71SWBChevy
Post Whore
71SWBChevy's Avatar
Re: 71 leaf spring frame swap on my 67.
Swap the 305 for a 350, other than that sounds like a plan.
Drew
'71 Chevy 350/TH350 Hugger Orange
Currently just a rolling frame, body work soon to follow!!!
Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927
Daily Driver: 1997 Chevrolet S-10 with more gears than pistons
71SWBChevy is offline   Reply With Quote
Old 03-16-2006, 01:16 AM   #3
longhorn71
longhorn71's Avatar
i think it wouls save you some time then doing all those upgrade on your 67 frame
longhorn71 is offline   Reply With Quote
Old 03-16-2006, 01:53 AM   #4
Ron 586
RIP Mr Ron
Ron 586's Avatar
You have your work cut out for you whichever way you go. But I think your on the best plan now. Good luck.
Ron (Mr Round Tuit)
Be kinder than necessary, for everyone you meet is fighting some kind of battle
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Ron 586 is offline   Reply With Quote
Old 03-17-2006, 07:37 PM   #5
rodnut randy
I don't quite understand how to reply to a certain person, but I upgraded my front suspension by bolting a complete 83 1/2 ton frt. suspension in my 70 frame. this gave me power disc brakes and power steering and all but 2 of the bolts dropped right into the 70 frame. I did have to drill 2 new holes, but other bolts had it lined up .so it was easy.
rodnut randy is offline   Reply With Quote
Old 03-17-2006, 08:42 PM   #6
davidh
davidh's Avatar
The 67 frame would still have to be dimpled for the power steering box regardless(have to remove the front clip for this anyway) then switching out the rear to 5lug.
