Old 03-16-2006, 03:10 AM   #1
smiley68
smiley68's Avatar
Drive Shaft problems
Hello all,
I have a question about a drive shaft. (again) I was wondering how hard it is to replace the carrier baring and two peice drive shaft. I have a 68 swb with a granny low four speed. The original tranny was three on the tree and it had a single driveshaft. My existing is too short. I am trying to stay away from having one built. (just had a baby) money is low. And I intend to put an auto in someday when I do the rebuild. I just want to drive the truck for a while now. If it is easier to replace it with a two peice and the carrier baring I'll go that rout. Any suggestions would be great. Also if the two peice is the key. Any suggestions were to find one. My local junk yards have few 67-72's and most are LWB's. This is the last major piece to finish to get it road worthy and has become quite frustrating.
Thanks,
Smiley
smiley68 is offline   Reply With Quote
Old 03-16-2006, 11:41 AM   #2
farside847
farside847's Avatar
Re: Drive Shaft problems
here is info from when I did mine....
http://67-72chevytrucks.com/vboard/s...d.php?t=171772
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 03-16-2006, 11:56 AM   #3
junkyardjohn
junkyardjohn's Avatar
I'm Not To Sure About What You Are Trying To Accomplish ,but Locally Here, You Can Get A Drive Shaft Retubed & Balanced For About The Price Of Two Tanks Of Gas. (around $100) John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 03-16-2006, 09:40 PM   #4
smiley68
smiley68's Avatar
Thanks for the info
Does anyone know your here! GOOD!
Old 03-18-2006, 06:55 AM   #5
4x4Poet
Removing the u-joints just needs some pliers, sockets, and a good size vice. Pulling the yoke off the carrier bearing, so to speak, can be difficult, but if you pull the u-joints yourself, having a driveshaft shop just pull the yoke (if necessary) would reduce costs considerably. The service manual has some procedures and pics of the process. Good link above, too.
Greasable U-joint crosses should be ~$13 x3. I found the donut style carrier bearing at my local bearing sales for ~$22. Auto parts stores wanted at least $5 more.
Your post confused me some. Does your truck already have the carrier bearing crossmember? I ask because you said the truck had a single piece driveshaft when it had the 3-speed which would necessitate the removal or cutting of the carrier bearing crossmember.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 03-18-2006, 07:06 AM   #6
cdowns
cdowns's Avatar
I'm lazy, i just drop off at the driveshaft shop and pick it up a day or so later but i do paint it myself
