03-16-2006, 11:30 AM | #1 |
71 4X4 Rear Cab Brackets?
I am in need of 2 rear cab brackets or cab mounts. Its a 71 4X4 and I'm not sure if they are different than the 2wd ones. These are the mounts that support the cab on the rear and are mounted on the frame. Thanks Rick
03-16-2006, 01:50 PM | #2 |
Re: 71 4X4 Rear Cab Brackets?
I don't believe there's any difference in the brackets themselves just the height that there mounted on the frame. 2wd's are mounted higher and 4x4 lower.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
03-16-2006, 02:10 PM | #3 |
TOTY 2006
I have a 67 frame that is cut onto peices, would not be too hard to for me to pull the support brackets. Let me know if you want them.
