Old 03-17-2006, 11:22 AM   #1
Myself
Help to I.D. 4 speed please.
I got a '67 lwb parts truck last week. The trans is a 4 speed. The option on the glove box door says 4M20AN . The reverse gear is all the way left and down, never seen one like this. Anybody know?
Myself is offline   Reply With Quote
Old 03-17-2006, 11:28 AM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Re: Help to I.D. 4 speed please.
SM420
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-17-2006, 04:34 PM   #3
Myself
So it looks like with those ratios, as far as street driving, that trans is junk. Right??
Old 03-17-2006, 04:52 PM   #4
JAKES 68GMC
Aluminum slot wheels rule...
Depends what you are going to do with the truck. If you want to shift fast and hot-rod around, than probably not the tranny of choice. If you just want to cruise around once in awhile, then I think it would be fine.
I guess it would be more like a personal preference thing.
JAKES 68GMC is offline   Reply With Quote
Old 03-17-2006, 05:07 PM   #5
dennislbrooks
dennislbrooks's Avatar
If it is decent--I have interest--I have a PTO that fits it.
dennislbrooks is offline   Reply With Quote
Old 03-17-2006, 06:39 PM   #6
TP from Cntl PA
TP from Cntl PA's Avatar
What is wrong with a 420 for driving? With the granny 4's, you only actually ever use 2nd, 3rd, and 4th. Loaded is the only time you ever need 1st, and it better be a big load.
Ratio's aren't much different than a 3 spd sag.................I can't tell much difference between them and the SM-465's I run.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 03-17-2006, 07:56 PM   #7
Scrubby
Check out GMTrucks.org
4th gear is still 1:1 which is the same as you will get with any non overdrive transmission manual or auto. This trans should be fine for the street.
Scrubby is offline   Reply With Quote
Old 03-17-2006, 08:30 PM   #8
72armyswbtruck
72armyswbtruck's Avatar
I agree and if you are looking for someone to trade or sell it to, besides dennis, Jeep owners love them because they use the tranny and mount it up to a 350 during the 350 swap.
BTW Scrubby I agree totally
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-15-2006, 08:49 PM   #9
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
My truck has the SM465. It's similar to the SM420. 2nd, 3rd and 4th are all geared about the same. However, the SM420 has a very steep 1st gear. Like 72Army said, Jeep drivers and even first gen Bronco drivers really like it for it's rock crawling capabilities.
However, take off in 2nd gear with a 3.07 rear end is close to what an auto trany in 1st gear with a 3.73 rear end gets. Thus, I have surprised a few of my auto trany car friends over the years with a good beatin' at the hands of an old Chevy truck in the 1/4 mi.
With that in mind if you run a 3.07, someone with a 3.73 would have to have a .82 OD to match the engine RPM's of the 3.07 SM420/465 in 4th gear.
SM420-465's run well with a 350 that has a long flat torque curve.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 04-15-2006, 11:30 PM   #10
wolfthing2000
Best tranny for any Jeep!!!! I had a Muncie 4 in my CJ-5 which was fine for drags or hilol climbs, then I put a SM420 behind it's Buick V-6 and it is a Jeepers dream!!! Very low geared and TOUGH!!! Meant to be!!!
I drove with one in a 66 Chevy 3/4 ton that I purchased 2nd owner and 50,000 miles in 1970 and I hot rodded and drove that truck until 1993 with campers , towing, snowing and blowing !!! That was the best truck ever. I would still have it except my EX killed it in a divorce let some boyfriend hack it and got sold after setting dead for 3 years . Someone got it for prolly a few hundred or less.
Excellent tranny. Probably still an option in those years because Chevy truck people weren't ready to change just yet, even though there was the 465. The granny gear is lower and straight cut and you actualy engage that whole mesh, not like the 465 with dogs. They sound way cool too!!!!
wolfthing2000 is offline   Reply With Quote
Old 04-15-2006, 11:34 PM   #11
wolfthing2000
67 must have been a transition year when both were available. I have a SM420 in the garage right now mated to a Rockwell 221 Timken transfercase that came out of a 67 4x4 3/4 ton.
Old 04-15-2006, 11:42 PM   #12
wolfthing2000
1947 -1967 chevy and GMC trucks. used also in a military vehicle called the Gamma Goat I believe . It was like a cabover and the tranny had a remote style cover shift set up rather than a cane shift. THE one i have in mynJeep was one of thjese and came in a box that was poured with a foam packing that surrounded the tranny. It was olive drab and slathered in cosmoline bran spanking new!!! That's right a brand spanking new 1947 technology tranny packed new in a box and manufactured in the mid seventys for the military ( not GM) and unpacked in 2002 and installed with a top from a wrecdking yard for the cane shift.
What a gear box!!!!!
Old 04-16-2006, 12:40 AM   #13
68C15
blood type; Retumbo
68C15's Avatar
what did GM use in the 1/2t in 68? did they have some of the 420s left over?
the reason I ask is I think mine had one. I'll have to check in the garage in the morning.
68C15 is offline   Reply With Quote
Old 04-16-2006, 06:36 AM   #14
'68OrangeSunshine
'68OrangeSunshine's Avatar
I heard Canadian production lines used the 420 into 1969 -- maybe later. U.S Chevy was supposed to change over to the 465 in the '68 model year. GMC sometimes used up older components after Chevy had moved on.
My '68 C/10 Stepside has the 465. [Fremont truck]
