![]() Join Date: Feb 2004
Changing from a BBC to SBC
OK, I am getting ready to put in a small block crate motor and want to use the newer style mounts and towers, What all will I have to do for this, Also I will be using a 400 tranny, Any suggestions? Thanks
Michael
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
#2 | |
Re: Changing from a BBC to SBC
Nope I still have it, don't worry, if the other guy doesn't buy it, I will still have it for a little while and YES IT IS STLL FOR SALE, check the for sale post.
I had the 396 out of my '69 for a while & had a 350 in it with a 400th. It was a direct bolt in. I dont know anything about how exhaust manifolds fit because I was running chevelle headers...corn
What about the drive shaft? And did you have to move the motor mounts forward or backwards? Did you use the newer style motor mounts?
I pulled one engine out & bolted the other one in. Unbolted the motor mounts from the BBC, bolted them on SBC. Thats it...
Too Dumb To Know Better
I went the other way with my 78 K20. 350 to 454. required new exhaust head pipes and I had to lose the fan surround. I used the small block towers and mounts. Everything fit fine.
Sweet, I think then that I might just keep these $200 set of 72 engine mounts and use them for the truck instead of selling them. I don't know though, $200 bones is $200 bones
Swap the mounts. Like you said they are worth something, and sb stands and mounts are dirt cheap. Use the extra $$ to buy other parts you need.
"You can take the man out of PA, but you can't take PA out of the man" |
