03-17-2006, 03:33 PM | #1 |
Jamie Hyneman is my twin
Carrier bearing?
Last night I took down my rear dirve shaft, to install a new carrier bearing, and some u-joints. I got the u-joints out thanks to my cut-off wheel, but couldn't get the bearing to budge more than 1/32 of an inch or so. I got the dust cover off, but not the bearing.
Do I need to take it to NAPA? Is there another way other than a BFH because I've tried that. Service manual says to use a slide hammer which I don't have. The spline is 6 inches long, I don't have a puller with arms that long. thanks ahead of time for the ideas.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
03-17-2006, 04:28 PM | #2 |
Re: Carrier bearing?
Took it down to NAPA over lunch, cause my wife wasn't home to talk to.
03-17-2006, 06:29 PM | #3 |
its all about the +6 inches
I always say a hammer has no buisness around a hunk of metal that spins 3000 RPM... you wouldn't do it to your crankshaft.
03-17-2006, 06:53 PM | #4 |
i just took mine to a shop and had it pressed off
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
03-18-2006, 06:02 AM | #5 |
Yeah, if you've got it that far, a driveshaft shop wouldn't charge much labor to pull the yoke off the carrier bearing.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
03-18-2006, 10:17 AM | #6 |
i got the yoke off no trouble it was the bearing race that i couldn't get off
03-18-2006, 09:30 PM | #7 |
Yeah...I hate carrier bearings. I just had a 1 piece aluminum shaft made for my truck...had to modify the crossmember for it to clear, but all is well. Saves alot of trouble.
72 Chevy short stepside 350/350 tilt, vintage air a/c sunset Orange Metallic paint Early Classic 2.5/4 drop eagle series 211 wheels |
03-18-2006, 09:42 PM | #8 |
just get a good bearing and it'll last 30 years
03-19-2006, 03:03 AM | #9 |
Glad to see that it all worked out in the end, carrier bearings and u joints are a pain in the @ss
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" Last edited by 72armyswbtruck; 03-19-2006 at 03:04 AM. |
03-19-2006, 08:55 PM | #10 | |
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! Last edited by TP from Cntl PA; 03-19-2006 at 08:56 PM. |
03-19-2006, 11:21 PM | #11 |
Dude, something else is wrong then.
The carrier bearing should take all the power you can feed it. Your u-joints would break,or your shaft would twist and break before the carrier bearing would be afected by engine output. |
03-20-2006, 02:17 PM | #12 |
Out of the carpool lane.
Yep, Andy's right. But I still hate the hassle of trying to figure out what the problem really is when a simple solution is just a $150 1-piece dl.
Btw, I'll be putting mine up for sale if anyone wants one. It works perfectly, but I just don't need it anymore. I can give more info to a potential buyer-please contact me via PM.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 03-20-2006 at 02:19 PM. |
03-20-2006, 09:23 PM | #13 | |
Too much on the Low end, and something has to give.............I am supprised it hasn't been the tranny yet.......
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
